rereroara
rereroara
Visits: 18
Thank you, I'll def try and do that! :D
Visits: 22.1K
I can't help you with the latter (AFAIK you must sample) but you should at least check with the Noitom folks about your issues, particularly if you have one of the newer PN suits (the PN3, for example, is almost immune to any magnetic issues once properly calibrated). Even with my very early PN suits (I've had them all the way since 1.0) I never had any big issues but the Noitom people are very good about getting your troubles sorted out. At the very least I would start there.
rereroara
rereroara
Visits: 18
Hello people, A while ago I mocap-ed some simple movements using PN, and through Axis studio I exported those motions. They need a LOT of cleanup- the legs are sliding all over the place and the movements are jittery. (Hopefully i'll find somewhere with less magnetic inteference in the futurte, but that's a thing I need to look into in the future) The problem is, when I try and check the curve editor on iClone to make adjustments, I get no keys. I try and use sample parts to artificially make them, but if I get rid of those said keys they don't remove motion at all. They can edit, but not delete. All the mocap videos I looked up just magically have the keys somehow. Is there any way to get the keys without using sample parts? Thanks!
