Using rlMotion file to iclone lower 7 version
Posted By jab12zak12 3 Years Ago
Posts: 23.1K, Visits: 36.6K
iClone 7 needs to be installed alongside 3DXchange 7 Pipeline. How much you need to use iClone 7 depends on what you want to do with the animations in terms of editing. However, you can either export directly from iClone 7 or from 3DXchange 7 itself.
Please Note: 3Dxchange 7 has now been discontinued so if you don't already have it, you can no longer purchase it. All the features of 3DXchange are incorporated into iClone 8 and/or Character Creator 4 so 3DXchange is no longer required when exporting.
jab12zak12
jab12zak12
New Member (77 reputation)New Member (77 reputation)New Member (77 reputation)New Member (77 reputation)New Member (77 reputation)New Member (77 reputation)New Member (77 reputation)New Member (77 reputation)New Member (77 reputation)
Posts: 3, Visits: 18
Thank you so much for your reply.
And to run and use 3DXchange 7 , iClone7 must be installed and run properly
Is it right?
Hi...
Unfortunately your graphic card is not sufficient for iClone 7 which is required to use .rlMotion files. You have a GT210 series graphic card and the minimum required is a GTX400, and even that would only run with very simple scenes on the lowest graphic settings. Also to be able to convert .rlMotion files to FBX would require you have 3DXchange 7 Pipeline as iClone 7 on its own can't export to FBX.
jab12zak12
jab12zak12
Hi everybody
Really new with iclone so forgive me if my question looks so silly.
Actually i need convert some rlMotion file to fbx or .. , and as I searched rlMotion file just can be used upper version of iclone6.
When I try iclone6 in my computer, there was an error about directX11 and when I changed DR11 to 9 in (Graphic mode selection) the problem solved but I couldn't use rlMotion file in iClone6.and unfortunately I couldn't find similar thing in iClone7 and there weas same erroe , running iclone7.
Now my question
1_Is there any chance for my system to use iclone7 i attached my graphic card feature?
2_Is there any chance to use rlMotion file without usiong iclone7 or higher?
Thanks in advance
https://forum.reallusion.com/uploads/images/2a9b4faa-e9ea-40e5-84a7-4549.gif
