Susan (RL)
Susan (RL)
Visits: 2.8K
v8.21 released on Mar. 16th, 2023 Several enhancements and bug fixes.
Enhanced: - iC 8.2 has enhanced the Render > Render with Max Texture Resolution feature. Users now have the option to toggle it on or off depending on their needs.
- When exporting an FBX file from iClone and selecting a Export FBX > Target Tool Preset such as "3dsMax", or "Blender", a JSON file will also be exported for mapping in AutoSetup.
Fixed:
- Abnormal rendering as a result of using Expression Wrinkles while the diffuse, normal, and roughness textures on the head material (Std_Skin_head) do not match in size. Feedback Tracker
- iClone crashes when an iTalk file is dragged onto the Timeline > Expression track. Feedback Tracker
- Attempting to change the normal map of the head material ("Std_Skin_Head") on a character with General Expression Wrinkles applied may cause the program to crash. Feedback Tracker
- Certain Python plugins can cause the program to crash.
- Applying certain CC3 hair content causes physics settings and weight maps to go missing. Feedback Tracker
- When using ActorCore to apply a facial profile to a character, if the user does not select the Viseme option in the pop-up dialog, the original Viseme data of the character will still be applied and replaced.
- Export fails when Export FBX > Advanced Settings > Mouth Open as Morph is enabled.
