Import multiple objects in alignment next to each other
Posted By mdgameconcept31 Last Year
mdgameconcept31
mdgameconcept31
Posted Last Year
Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)
Posts: 58, Visits: 304
Hi,
Is there a way to import into iclone 7 several objects in .obj (or .fbx) format at the same time and in a way aligned one next to the other like in the picture?
https://forum.reallusion.com/uploads/images/e7a402a1-a45f-4580-a9a9-bf9d.png
Thanks in advance
Last Year by mdgameconcept31
michaelrbarton
michaelrbarton
Posted Last Year
Posts: 974, Visits: 11.2K
Do you have 3DXChange 7? If you don't, you can't import FBX and OBJ into IC7.
However, CC3 lets you import FBX and OBJ items. But you have to go to
Create and Accessory at the Top.
Last Year by michaelrbarton
Posted Last Year
Posts: 15.8K, Visits: 31.3K
You can only import a single prop at the time.
So you would create a dummy prop in the application your are exporting from first and then attach each of the other props to it. This will keep them in position when you import the dummy prop.
After importing you can then detach each of the props from the dummy to separate them.
Last Year by animagic
mdgameconcept31
mdgameconcept31
Posted Last Year
Hi,
sorry to answer only now
Thank you for your answers but I think the process looks quite complicated lol
