Hello all, I'd really appreciate any help I can get on this matter as it's a major blocker.
I've been trying to import an FBX to CC4 to test its blend
shapes with live facial mocap.
The FBX has been created and exported in Maya, with blend
shapes assigned and named accordingly. It also has a quick rig from Mixamo, for testing purposes.
The process I'm following is this one and it has always worked fine before:
https://www.youtube.com/watch?v=QOAs8RtTH90 The only thing I'm doing differently from the video is that I'm using the CC4 Extended face morphs, not just the Standard ones, but that has never been a problem.
For whatever reason now, when I get to the point at 2:59 (Edit Expressions > FBX File > selecting the FBX), the OK button is greyed out. I've checked that the names of all the blend
shapes are spelled correctly and they all match (again, it has worked fine before).
Now, the only way for the button not to be greyed out is creating a Target Category, after which I can finally press "OK", but CC4 adds a "_0" at the end of the name of each blendshape/morph and, by doing so, none of them get recognised and assigned to the proper category. They do work, but they're all on the Target Category.
TLDR; Even though the morphs are named correctly, CC4 won't let me import them unless I create a Target Category and then adds a "_0" at the end of their names.
