Hi animagic :)
I mean like in premiere or unreal etc? In a project you can have separate sequences, which are different timelines. You can quickly switch between them.
IClone currently works with Projects only, and each project needs you to go to the file menu and open it.
It would be ideal if iClone had projects that were collections of animations that are all part of the same “project” that you’re working on, like other software. So a project is your short film, for example, let’s call it “Bank Heist Madness”. And then you have a sequence for “the arrival” where you make the outside street scene, where they drive up. Then you make a sequence called “entry” where they first enter. Etc.
You can also then keep all your “sequences” for a single film together easily. Plus, you can have folders in the “project” that has copies/links for your most used items. At the moment, you have to drill down into the content tab into /template/custom etc for each individual item. But for the bank heist project, items I want to reuse and selections of mocap I want to use could be in the Project window.
The project-as-sequence setup of iClone was great many years ago, but now iClone is a fully fledged filmmaking powerhouse. :) so a “project + sequences” setup would be much better, in my opinion.
Toby
75% of original size (was 667x19) - Click to enlarge
virtualfilmer.com | youtube
