Macdonut
Macdonut
Visits: 208
After CA5 crashes, I am getting a pop-up window saying, "Unsaved project data found. Would you like to update your project with unsaved change?"On answering, "Yes", all that happens is that I am taken to the last location that I used a file from, on this occasion a folder with images in. I have added this problem to Feedback Tracker
yepkoo
yepkoo
Posts: 1.2K,
Visits: 1.9K
This is the same in CC4 and iC8. When the program crashes and you open it again, you will receive a warning as you mentioned, and you must first save this lost file by giving it a name by pressing Yes. Then your project should open.
---------------------------------------------------------------- https://www.youtube.com/yepkoo https://dev.epicgames.com/community/profile/bxvo/Yepkoo#learning
Macdonut
Macdonut
Visits: 208
yepkoo (12/21/2022) This is the same in CC4 and iC8. When the program crashes and you open it again, you will receive a warning as you mentioned, and you must first save this lost file by giving it a name by pressing Yes. Then your project should open.Aha! Makes sense. Will try that. Thanks.
