Last Active: 9 Months Ago
Visits: 54
Hi guys I'm new here and I would like to know how I export fbx from CC4 to another CC4 (different member key). I'm doing a project with a partner and when I try to import the FBX I get the message:
"Failed to load the file. Fbx Key is not valid." Procedure:My partner exports in FBX from his CC4, so I go to my CC4, then file, import, import, select FBX, then I press Character, then CC Avatar (standard), select the Key file and then I get the message: "Failed to load the file. Fbx Key is not valid." Is it possible to do this process ? Thank all
Posts: 23.1K,
Visits: 36.6K
hi... If you are both using CC4 then why not just supply the character file itself (ccAvatar). :ermm:If you use FBX with the FBXKey it locks the character to the copy of CC4 that exported it.
