fromsouthgames
fromsouthgames
Last Active: 9 Months Ago
Visits: 222
This problem is a really bad thing, I will explain why,If you import a character to a Game Engine only to get some renders, you would be just fine.However, when you try to develop a project/game, this is VERY Critic and problematic.In a project like this, you dont have ONE skeleton for each character, in fact you make all your humanoid character meshes share the same skeleton. So you only have ONE Animation blueprint (the code that drives the animation).WHen you break the Default, pre-defined, standard UE4 Skeleton, you are forcing a developer to Retarget ALL the animations, duplicate ALL the code for each different skeleton you import.
This ends up in a messing hell. So the question is, Can I have a character exported to unreal engine 5 with the skeleton as it corresponds to a compatible unreal engine default skeleton?Thankls
