yayettah
yayettah
Visits: 107
After importing from daz to CC, Genesis 8.1 texture looks so horrible and also has a black spot on hands as well. The image below is when i imported without adjustment and after adjustment.
 Hope to fix that in the coming updates or if there's a tutorial to handle that in a normal way without any problems, Thanks.
FEEDBACK TRACKER
luke (RL)
luke (RL)
Group: Power Developer
Visits: 5.6K
Hi, yayettah This is a known issue because the normal and bump map (grey) are in the character, the solution is to remove the bump map first and then you should see the correct result, thanks. https://kb.reallusion.com/Product/53102/Why-are-there-texture-defects-with-Daz-81-characters-imported-via-CC-Transformer-CCv41
