Fix for flickering shadows?
Posted By jeffkirkland 4 Years Ago
jeffkirkland
jeffkirkland
Last Active: 5 Months Ago
Posts: 290, Visits: 1.7K
Rampa (7/19/2022)
Crawling is exactly what you are seeing. I made a video exploring what is going on. basically, it's aliasing.
Thanks for that. I have a much better understanding of how shadows work now. Between the info in that video and a bit of post production magic, I'm confident I can eliminate 99% of my shadow problems.
Jeff Kirkland | Director • Cinematographer • Storyteller
Hobart • Tasmania • www.one18films.com
SYSTEM: AMD Ryzen 5 5500 | 32gb RAM | RTX 3060 12gb | 1tb SSD System | 44tb HDD Storage
Posts: 8.2K, Visits: 62.6K
jeffkirkland
jeffkirkland
Rampa (7/18/2022)
If you can light your scene with spotlights, you will have no flicker, PCSS or not. The flickering only happens with the distant light.
The sample of flickering (or is it more 'crawling'?) I posted were lit with a single spotlight and quite happily flickering away.
jeffkirkland
jeffkirkland
mark (7/18/2022)
Is PCSS enabled under the Light tab? If so, adjusting the Softness value may help.
Is TAA checked under the Project tab?
PCSS is disabled and TAA is enabled.
mark
mark
Posts: 4.9K, Visits: 16.7K
PROMO-BACK2
Posts: 5.3K, Visits: 16.8K
Good Luck, keep us posted!
jeffkirkland
jeffkirkland
4u2ges (7/18/2022)
 As expected, removing the animation stopped the flickering.
This is highly transparent hair - specially in the front. Can you claim that shadow is flickering here?
Being a cinematographer/editor/colorist for a living, I've got a keen eye for even a lone pixel misbehaving in a single frame of footage but while I can see an extremely small amount of crawl in there it's not enough that I'd be unhappy with the result. Certainly, I could probably fix what's there with some noise reduction in post.
My biggest concern is that what's subtle on a computer monitor is going to stand out like a neon sign when projected on a cinema screen.
Anyway, thanks for the tips - they're much appreciated. I'll try everything you've mentioned and see if I come up with a winning formula.
That is what I wanted to hear.
So yes, it is not your hardware or corruption of some sort. It is normal for iClone shadow system.
The second clip looks better because hair bunches/strands are less transparent than hair in the first video.
iClone has hard time rendering low resolution shadows through fluctuating (because she moves relatively to the light source) transparency such as hair.
The shadow resolution would make some difference. But again, as I mentioned in the other thread, light distance is a key factor.
2048 Shadow resolution
from a distant light would look different, than same shadow resolution from a closeup light.
So disable shadow from a distant Spot Light.
Create Spot Shadow at the same line of sight as the existed Spot Light, but bring it closer to the face.
Play with range/angle/shadow resolution.
If it does not make much difference, then play with viewer perception. Make them accept flickering as normal!
The hair in your render is mostly static (even the first one where physics was enabled).
It is indeed looks very odd - static hair and flickering shadow behind it.
She appears to be outside. So animate hair with the wind. Make it move! Then flickering would seem normal to the viewer.
And also draw viewer attention to something else - highlights, like "wet" eyes, back light reflection moves through the hair... something that would draw attention away from stupid flickers :)
jeffkirkland
jeffkirkland
4u2ges (7/17/2022)
And if you disable hair physics and remove her animation (but leave camera movement) would flickering stop?
I got to the office and realized I hadn't saved the demo file so I had to quickly recreate it.  As expected, removing the animation stopped the flickering. Disabling the physics made no difference. I also replaced the hair and while the flickering was better, it still wasn't gone.
I've attached two new videos, the first being the hair with no physics, the second being with different hair but you can still see the flicker, especially down on her chest.
EDIT: On YouTube the alt hair version doesn't look as bad as it does playing back the rendered file on my screen here.
Thanks for taking a look...
