Distorted models when importing to Unreal Engine 5 using the Auto Setup.
Posted By ojala.juha 4 Years Ago
Distorted models when importing to Unreal Engine 5 using the Auto...
ojala.juha
ojala.juha
Senior Member (416 reputation)Senior Member (416 reputation)Senior Member (416 reputation)Senior Member (416 reputation)Senior Member (416 reputation)Senior Member (416 reputation)Senior Member (416 reputation)Senior Member (416 reputation)Senior Member (416 reputation)
Posts: 27, Visits: 165
So I have been fighting this problem for two days and still, no solution found. I tried with brand new Unreal Engine projects, different IClone models and the newest version of the plugin and non seems to do anything.
The problem is this:
Whenever I Export an animation from IClone using Unreal Engine presets and then import the animation Unreal Engine, the model that plays the animation gets very twisted. I tried to import the animation with the same mesh it played inside IClone but the same problem still remains.
Here are the steps:
I apply animation to the model
I Export as FBX using Unreal Engine presets:
In Unreal Engine I import using default presets:
The animation is distorted.
Strange thing is that when I press import and get the Auto Setup menu and I disable using the auto setup, then the character and animation come normally and work, but as soon as I allow Auto Setup, the twisting happens. I tried to import the character using Auto setup and only animations without it, but that didn't work and twisting happens.
So every help is much appreciated! Oh, and I guess I should mention that I tried to bring Unreal Engine mannequin to CC4, characterized it and put animation to it and that worked. The default CC characters have the problem.
