Hello Everyone, with iClone 8 release, we have provided the compatible Omniverse Audio2Face Plug-in (Beta) for the new iClone. The following is the information for the updated plug-in. For the complete guideline on how to use Audio2Face and iClone, please refer to
this post.Release Note:
* Support iClone 8.0
* Added conversion blendshape preset file into the Python script zip file along with the addition of CC4_Extended.json and CC4_Standard.json.
52% of original size (was 962x185) - Click to enlarge
Notice:For better facial animation, a lot of custom morph sliders have been added to CC4 characters, causing the number of morph sliders to differ for each character.
Omniverse Audio2Face reads preset files according to the order of the morph sliders, consequently, Audio2Face plugin’s blendshape conversion presets are not directly applicable to CC4 embedded characters like Kevin, Camila, Alika, Eddy, etc.
You need to follow the steps below in order to correctly use Audio2Face plugin presets.
- Make a backup of Audio2Face (ui.py) within their respective install paths.
Default path example: C:\Users\[Username]\AppData\Local\ov\pkg\audio2face-2021.3.3\exts\omni.audio2face.tool\omni\audio2face\tool\scripts\ - Download ui.py from Google Drive
- Copy and paste the "ui.py" file to the install path.
Note: To revert the changes, just re-use the backup from Step 1.
* NVIDIA is aware of this problem and the workaround will not be necessary with the next Omniverse Audio2Face update.
CC Character Blendshapes Conversion Preset Guideline:
Please check THIS DOCUMENT for details.
If you need the step by step tutorial, please check this
post.
From Reallusion Team
