Amper Sand
Amper Sand
Visits: 5.2K
omotionmedia (7/13/2022) I like the brick texture and the background.I don't deserve too much credit for that, lol
______________________________________________________________________________ Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend In progress: Black Mamba AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
omotionmedia
omotionmedia
Visits: 321
Amper Sand
Amper Sand
Visits: 5.2K
livecleo (7/13/2022) Could you plz tell me how you made the bobs jiggle? I love themSelect the character, then in the Modify panel scroll to bottom, there's a Spring section. In Select Spring there are three (for CC3+) or two (for CC3). For each spring turn Activate to ON and adjust its three parameters to get desired effect. P.S If you're using IC7 and CC3+ character, I recommend to tap the "Open" button in the Spring section to load one of two pre-defined spring profiles (.spx), CC3+_Breast_Spring_Normal or CC3+_Breast_Spring_Heavier.
2 Years Ago by
Amper Sand
livecleo
livecleo
Visits: 97
Amper Sand
Amper Sand
Visits: 5.2K
4u2ges (7/3/2022)
Oh no! You should not buy a piano. You could have merged upright piano with separate chair from my House Interior project that you have And in default iClone content 3D Blocks > Pipes there are some pipes and pipe connectors you could use. The guy was very kind, he sent me by the morning a modified version having the chair as a sub-prop, so I used it I forgot about the built-in pipes, thanks for reminding me, I already combined them in the clip, looks nice.
2 Years Ago by
Amper Sand
Last Active: 12 hours ago
Posts: 5.2K,
Visits: 16.3K
Oh no! You should not buy a piano. You could have merged upright piano with separate chair from my House Interior project that you have And in default iClone content 3D Blocks > Pipes there are some pipes and pipe connectors you could use. Be waiting for the clip.
Amper Sand
Amper Sand
Visits: 5.2K
You gave me an idea, so below's a small (unlisted) update. I wanted to use your piano, but it was too large for the room so I bought a short piano from CGTrader - I wrote the guy a PM if he can provide me an opacity mask to hide the chair, it's not a sub-prop so I cannot arrange it. But from your piano I took the music sheet, lol. I'm thinking to use for your soundtrack my favorite Mixamo character (I know you love it too ) because he's prone to create mess around - I think I will have to find in my collection som pipes, water pipes
https://www.youtube.com/watch?v=HOuCEaS0pTA
P.S And your teddy is, as always, amazing
2 Years Ago by
Amper Sand
Posts: 5.2K,
Visits: 16.3K
Amper Sand (7/3/2022) IC8 mirrors and a mirrored motion. In this particular setup, the ultra widescreen format suited very well. In my opinion, the devs at RL did a very good job in improving the overall lighting and rendering quality - to my standards, this video is a very good native rendering; keep in mind, me I'm not using not even LUT or post processing filters/enhancements, everything is done by RL's lights and textures. Enjoy!
Awesome The only thing missing is a soundtrack. I have added that for you. Just start both clips at the same time
2 Years Ago by
Amper Sand
Amper Sand
Visits: 5.2K
2 Years Ago by
Amper Sand
Amper Sand
Amper Sand
Visits: 5.2K
There's an issue in the Suntan skin effect (happens in both CC3 and CC4) - it looks like it applies a different roughness to the head texture compare to body's, see the slight "shining" above clavicle: P.S I think I could add a small mole on her right, above the lip, for more dramatic effect.
