Very Larg workspace size. How to make it small?
Posted By beshoo 3 Years Ago
beshoo
beshoo
Junior Member (187 reputation)Junior Member (187 reputation)Junior Member (187 reputation)Junior Member (187 reputation)Junior Member (187 reputation)Junior Member (187 reputation)Junior Member (187 reputation)Junior Member (187 reputation)Junior Member (187 reputation)
Posts: 19, Visits: 94
Dear all; Please have a look at my workspace size:
https://i.imgur.com/AIBWfNq.png
It is enormous, and I can not work with, while my screen is large 1707 x 1067.
How can i resize the size of the workspace?
Posts: 23.1K, Visits: 36.6K
Hi...
Please check in Preferences (CTRL+P) that you don't have "Enlarge Font and UI" checked. If you do uncheck it and restart CTA4.
Also, try opening your "Display Settings" (right click the Desktop) and make sure the "Scale & Layout" setting is at the recommended setting for your screen resolution, If it is at the recommended level already, you can adjust it manually to see if this improves the size of the UI in CTA4.
beshoo
beshoo
Peter (RL) (6/2/2022)
Hi...
Thanks!
I fix this via the following steps :
Windows changed "Disable display scaling on high DPI settings" to:
Change high DPI settings > (Checkbox) Override high DPI scaling behavior. Scaling performed by: Application.
Just had to select "System" from the drop-down menu and now, all apps run on 125%, and the app I open runs on 100%.
Thank you so much.
Solved
