Multi-Passes Rendering Test
Posted By GOETZIWOOD STUDIOS 16 Years Ago
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posted 16 Years Ago
Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)Distinguished Member (9.2K reputation)
Posts: 1.2K, Visits: 7.2K
Hello,
As I'm trying to overcome iClone rendering limitations, I've made a test using multi-passes approach as we often do in production.
This allows for more than four shadowed ligths, the correct use of ambient occlusion ( not in the diffuse ) but also this solves a big problem I had trying to get ambient occlusion maps into the 'Blend' material channel : memory ! Because using unique uvs imply using very high-def textures for baking diffuse, bump etc.. Up to a point I couldn't load this set into iClone. The set is 'UrbanFuture3' ( Daz3d/Stonmason ) that I've imported into Softimage|XSI. From there I was able to create a second set of UVs, bake ao maps, etc.. then export 2 versions ( one for each UVs set ) into iClone through 3DXchange :
You can download a short animation here :
iCloneMultiPassesTestA.mov ( 1280x546 | 2:35 | 24fps | 10527Ko )
As you can see I have anti-aliasing problems but that is to be expected with raw OpenGL anti-aliasing ( and perhaps my card is not enough ).
Would be great to have an 'enhanced' anti-aliasing mode into iClone though ;)
That said, multi-passes rendering is an option not to be forgotten, even with iClone, as this gives you far more power than straight rendering, albeit at the price of a 'little' more work.
Cheers,
Guy.
guy rabiller | GOETZIWOOD STUDIOS
"N.O.E." (Nations Of Earth) Sci-Fi TV Show, Showrunner.
Threaded View
Threaded View
Forum Post Multi-Passes Rendering Test By GOETZIWOOD STUDIOS ( 16 Years Ago )
Forum Post All I can say is "Wow." That video is amazing. I am still not clear... By Illustrator Cathy ( 16 Years Ago )
Forum Post very nice effect - multi-pass as in rendering as in layers and... By aknzrdude ( 16 Years Ago )
Forum Post Amazing results guy. so are you saying use various atmosphere... By steven_20090922190316893 ( 16 Years Ago )
Forum Post Hello Steven, thanks. [quote][b]steven_20090922190316893... By GOETZIWOOD STUDIOS ( 16 Years Ago )
Forum Post Hello, [quote][b]Anim8torCathy (5/14/2010)[/b][hr]../.. I am still... By GOETZIWOOD STUDIOS ( 16 Years Ago )
Forum Post Excellent job Guy, you do have some fantastic skills man, but you do... By stuckon3d ( 16 Years Ago )
Forum Post [quote][b]stuckon3d (5/15/2010)[/b][hr]Excellent job Guy, you do have... By GOETZIWOOD STUDIOS ( 16 Years Ago )
Forum Post Hi Guy- I do understand what you are doing now and realized I could... By Illustrator Cathy ( 16 Years Ago )
Forum Post [quote][b]Anim8torCathy (5/15/2010)[/b][hr]Hi Guy- I do understand... By stuckon3d ( 16 Years Ago )
Forum Post " Also, when 4.2 comes out, layering will become much easier. :w00t: "... By Illustrator Cathy ( 16 Years Ago )
Forum Post [quote]Excellent job Guy, you do have some fantastic skills man, but... By bluemidget666 ( 16 Years Ago )
Forum Post [quote][b]bluemidget666 (5/15/2010)[/b][hr][quote]Excellent job Guy,... By stuckon3d ( 16 Years Ago )
Forum Post Hmm it does LOOK complex... however I think if I knew how to seperate... By Dreamcube017 ( 16 Years Ago )
Forum Post [quote][b]Dreamcube017 (5/16/2010)[/b][hr]Hmm it does LOOK complex...... By GOETZIWOOD STUDIOS ( 16 Years Ago )
Forum Post Hey Guy- One more question - pardon my insatiable curiosity. Are... By Illustrator Cathy ( 16 Years Ago )
Forum Post [quote][b]Anim8torCathy (5/16/2010)[/b][hr]../.. Are you using levels... By GOETZIWOOD STUDIOS ( 16 Years Ago )
Forum Post [quote][b]grabiller (5/17/2010)[/b][hr][quote][b]Anim8torCathy... By Illustrator Cathy ( 16 Years Ago )
Forum Post [quote][b]Anim8torCathy (5/17/2010)[/b][hr]../.. I want to reiterate... By GOETZIWOOD STUDIOS ( 16 Years Ago )
Forum Post [quote][b]grabiller (5/20/2010)[/b][hr][quote][b]Anim8torCathy... By Dreamcube017 ( 16 Years Ago )
Forum Post To be honest Guy, for me . . . most of it is unclear, but I won't ask... By gizmo ( 16 Years Ago )
Forum Post [quote][b]gizmo (5/16/2010)[/b][hr]Please continue with your work in... By Paumanok West ( 16 Years Ago )
Forum Post Thanks for sharing so much information with us - this is quite... By Dulci ( 16 Years Ago )
Forum Post The results are AWSOME ! fingers crossed RL look at this and address... By bluemidget666 ( 16 Years Ago )
Forum Post I am very bad at English, so I will try to convey my thoughts in... By kurzal ( 16 Years Ago )
Forum Post Now that is impressive! I wish I had the time to do muti-pass and... By Capemedia ( 16 Years Ago )
Forum Post [quote]If you buy a car for passenger transportation, it is likely... By bluemidget666 ( 16 Years Ago )
Forum Post kurzal, I'm with you on the subject of the importance of script... By animagic ( 16 Years Ago )
Forum Post [quote][b]zuijlen (5/17/2010)[/b][hr]The real-time aspect of iClone is... By Paumanok West ( 16 Years Ago )
Forum Post Could these multiple render settings eventually be added to iClone's... By peteradam6 ( 16 Years Ago )
Forum Post Hello, [quote][b]kurzal (5/16/2010)[/b][hr]../.. iClone is... By GOETZIWOOD STUDIOS ( 16 Years Ago )
Forum Post Hm thanks Guy. This seems a bit more doable now that you've explained... By Dreamcube017 ( 16 Years Ago )
Forum Post OR, in the meantime, if you don't have the talent and training Guy has... By Paumanok West ( 16 Years Ago )
Forum Post Hey West that's not a bad idea. Hm I think for the textures though... By Dreamcube017 ( 16 Years Ago )
Forum Post Guy what you are doing is amazing and I totally support it. In fact I... By Capemedia ( 16 Years Ago )
Forum Post [quote][b]Capemedia (5/17/2010)[/b][hr]I'm one of the first to argue... By Paumanok West ( 16 Years Ago )
Forum Post Hello, [quote][b]Capemedia (5/17/2010)[/b][hr]Guy what you are... By GOETZIWOOD STUDIOS ( 16 Years Ago )
Forum Post That post two posts above... = best post ever. That's why I... By Dreamcube017 ( 16 Years Ago )
Forum Post [quote][b]Dreamcube017 (5/17/2010)[/b][hr]That post two posts above...... By Capemedia ( 16 Years Ago )
Forum Post "After that I'll look into it, and find a way to create tutorials for... By Illustrator Cathy ( 16 Years Ago )
Forum Post Agreed. I'm willing to help you if you need it as well. By Dreamcube017 ( 16 Years Ago )
Forum Post Same here Guy, if you need anything just ask :D Taking iClone to the... By Capemedia ( 16 Years Ago )
Forum Post "Sounds like a job for..." Mitch strolls over to the BatSpotlight,... By Paumanok West ( 16 Years Ago )
Forum Post Hello, [quote][b]Anim8torCathy (5/20/2010)[/b][hr]../.. There... By GOETZIWOOD STUDIOS ( 16 Years Ago )
Forum Post Mainwhile I've done another test, this time with some characters : ... By GOETZIWOOD STUDIOS ( 16 Years Ago )
Forum Post [quote][b]grabiller (5/24/2010)[/b][hr]I've also discovered that we... By Paumanok West ( 16 Years Ago )
Forum Post WOW ...... :w00t: By bluemidget666 ( 16 Years Ago )
Forum Post Again - Totally Amazing. :w00t: Cathy :hehe: By Illustrator Cathy ( 16 Years Ago )
Forum Post Now That looks awsome. I wish I had the time these days to spend in... By Christy0 ( 16 Years Ago )
Forum Post Amazing film-look. There are some frames you'd swear could have only... By Paumanok West ( 16 Years Ago )
Forum Post Wow I must take this into consideration while I'm making my set.... By Dreamcube017 ( 16 Years Ago )
Forum Post I can say nothing other than fantastic. Seeing you professionals... By Wolfzone Digital ( 16 Years Ago )
Forum Post Hello, [quote][b]Paumanok West (5/24/2010)[/b][hr]../.. Yes, and... By GOETZIWOOD STUDIOS ( 16 Years Ago )
Forum Post [quote][b]grabiller (5/25/2010)[/b][hr][quote][b]Paumanok West... By Paumanok West ( 16 Years Ago )
Forum Post Holly sh!tting COW!!!!!! Guy that was absolutely stunning and the... By Capemedia ( 16 Years Ago )
Forum Post Oh, I almost missed this one... (You should post in the showcase... By Bigboss ( 16 Years Ago )
Forum Post Hey guys, thanks a lot ! [quote][b]BigBoss40... By GOETZIWOOD STUDIOS ( 16 Years Ago )
Forum Post Hi Guy, I just dropped by to say a heartfelt thanks. Your work is... By particleboy ( 16 Years Ago )
Forum Post Hello, [quote][b]particleboy (6/8/2010)[/b][hr]../.. Did you turn... By GOETZIWOOD STUDIOS ( 16 Years Ago )
Forum Post Thanks very much for your reply Guy, [quote]I always use external... By particleboy ( 16 Years Ago )
Forum Post [quote][b]particleboy (6/10/2010)[/b][hr]Thanks very much for your... By Dreamcube017 ( 16 Years Ago )
Forum Post Hello, I'm not sure to follow you here, but no, I've not removed... By GOETZIWOOD STUDIOS ( 16 Years Ago )
Forum Post hi it's possible to render normal map passe please By kilik ( 12 Years Ago )
