UE4 Build types, and problem with UnrealEd files due to AutoSetup plugin
Posted By kelbyvp 3 Years Ago
UE4 Build types, and problem with UnrealEd files due to AutoSetup...
kelbyvp
kelbyvp
Veteran Member (679 reputation)Veteran Member (679 reputation)Veteran Member (679 reputation)Veteran Member (679 reputation)Veteran Member (679 reputation)Veteran Member (679 reputation)Veteran Member (679 reputation)Veteran Member (679 reputation)Veteran Member (679 reputation)
Posts: 50, Visits: 539
Trying to build within UE4, and having problems with non-editor builds.
I have installed AutoSetup as instructed, and it works great when I run Unreal directly or when I run in Development Editor mode from within Visual Studio.  However, other build modes from within VS are causing problems.
First, any non-Editor build (eg, Shipping or Development) doesn't work due to the UnrealEd module, which is apparently referenced in the RLPlugin but doesn't work in non-Editor builds.  Which raises the question:  Once we have installed AutoSetup, are we supposed to remove it or something to build a non-Editor build?  If I just leave it, I get this error (which is what I would expect for a plugin that refences the UnrealEd module):
1>UnrealBuildTool : error : Unable to instantiate module 'UnrealEd': Unable to instantiate UnrealEd module for non-editor targets.
1>                        (referenced via Target -> Quest.Build.cs)
Second, if I try to build in DebugGameEditor mode, it builds fine within VS if I just build but don't run the local debugger; however, when I click the "Local Windows Debugger" button, I get the error
"The following modules are missing or built with a different engine version: RLPlugin Would you like to rebuild them now?"
I have had this error from time to time in regular DevelopmentEditor mode, and the solution has been to re-copy the AutoSetup Plugin folder to my project's Content folder.  But in DebugGameEditor mode, that isn't working.
I obviously need to be able to build my game in something other than Editor mode, and I would like to be able to build periodically to test my project in a shipping configuration.  But I need to have it be simple to switch back and forth between being able to import characters/anims from CC3/iClone and then testing the game in other build configurations.
