unregistering a plugin
Posted By frank_461853 5 Years Ago
jlittle
jlittle
Posts: 1.9K, Visits: 17.3K
Frank,
Attached is a program that you can load using the Script | Load Python menu item.
It shows several methods of removing a Menu Item/Action.
Jeff
RLMenuRemovalExample.zip (108 views, 1.00 KB)
frank_461853
frank_461853
Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)Senior Member (491 reputation)
Posts: 26, Visits: 98
jlittle (12/9/2021)
Are you trying to "unregister" your own menu item or the already existing ones?
If the existing ones, why would want you do this?
If all you want to do is disable certain plugins then my "Plugin Manger" will do that for you.
Once you "find" the main menu, you can then look at each of the menus child objects to "find" other menu items which then can be removed.
Jeff
i want to unregister my own plugin.
my initialisation it thus
def initialize_plugin():
    # Add menu
    ic_dlg = wrapInstance(int(RLPy.RUi.GetMainWindow()), QtWidgets.QMainWindow)
    plugin_menu = ic_dlg.menuBar().findChild(QtWidgets.QMenu, "Platform_menu")
    if (plugin_menu == None):
        plugin_menu = wrapInstance(int(RLPy.RUi.AddMenu("Platform lights", RLPy.EMenu_Plugins)), QtWidgets.QMenu)
        plugin_menu.setObjectName("Platform_menu")
        platform_action = plugin_menu.addAction("Stages")
        platform_action.triggered.connect(show_dialog)
despite this
when i unload or attempt to
def UnloadMe(toHandle):
# remove menu
    if (plugin_menu != None):
        #lAction =  plugin_menu.findChild(QtWidgets.QAction, "Stages")
        for ThatActions in ic_dlg.actions():
             print (ThatActions)
        for TotherAction in plugin_menu.actions():
            print (TotherAction)
returns nothing.
when you say "find  the main menu" do you mean by interrogating the "ic_dlg" handle?
jlittle
jlittle
Jeff
frank_461853
frank_461853
frank_461853 (12/8/2021)
in a python script how to i unregister a plugin from iclone 7's plugin menu?
is there a way of doing it from within python?
Thank you. there's no global area to store the handle. i did try getting the Actions collection of the Menu object but it retrieved only the default which is strange as i added an action.
jlittle
jlittle
Frank,
If you keep a pointer to the menu action that was created you can remove it by using the removeAction(action).
Jeff
frank_461853
frank_461853
Last Active: 11 days ago
Posts: 5.7K, Visits: 26.5K
Jeff Little has a Plugin Manager in the Marketplace that lets users decide if a plugin should be loaded at start or not. Cool tool. :cool::smooooth:
frank_461853
frank_461853
