Duplicate Frames
Posted By bjsskies 3 Years Ago
bjsskies
bjsskies
New Member (48 reputation)New Member (48 reputation)New Member (48 reputation)New Member (48 reputation)New Member (48 reputation)New Member (48 reputation)New Member (48 reputation)New Member (48 reputation)New Member (48 reputation)
Posts: 2, Visits: 32
Is there a way in iClone to detect duplicate frames? I want to be able to stitch a longer video together with a seamless transition (particle effects are involved).
Data Juggler
Data Juggler
Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)
Last Active: 3 hours ago
Posts: 1.7K, Visits: 5.4K
Can you define what you mean by duplicate frames?
Are you referring to a specific prop or character's position? Any frame without movement will be the same as the previous, so there could lots of duplicates depending on your definition of duplicate and scene.
Next question is why would there be duplicates? Is it a prop that repeats something in a loop?
I don't know of a built-in method, but a Python script could check an objects position against other frames, but it might take a bit to process 1800 or more frames against each other.
Another method would be to render all the images as an image sequence (instead of a video), and a program could check images for similar images, yet again this could be time consuming depending on number of frames rendered.
Tell me what you need to find and I can tell you more. (possibly)
Creator of the free website:
PixelDatabase.Net
A Free Online Text Based Image Editor
https://forum.reallusion.com/uploads/images/6e6663e2-0ecf-447a-ab3d-d49d.png
3 Years Ago by Data Juggler
Posts: 5.7K, Visits: 26.4K
There is no way to detect duplicate frames inside iClone, and such a feature wouldn't work in quite a lot of situations even if present.
Take the example of a simple half second pause in a scene - 15 frames in a 30 FPS render. 14 of them would be considered duplicates and removed leaving the clip with a 1 frame pause. w00t
The only successful way to do what you want is to use an video editing software (NLE). Particle effects need time to get started, and therefore require more frames to get to "full power". It's always best to start any effects at least 1-2 seconds into a scene and then remove the unwanted frames later in the NLE.
bjsskies
bjsskies
The issue I have is with particle effects where there's rain, fog, and waves. I can stitch a drawn out scene together in another video editor, but I'd like to be able to continue from a particular frame (continue where the particle effect left off) so the scene doesn't have a choppy transition.
Amper Sand
Amper Sand
Posts: 731, Visits: 5.2K
Particles are random, physics-controlled, there's no way to get "where the particle effect left off". And I'm almost sure this is valid for any 3D engine involving particles - otherwise, particles would be recordable/keyframable.
______________________________________________________________________________
Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend
In progress: Black Mamba
AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
