Hi Debbie
iClone on its own doesn't create characters, so you will need to use Character Creator 3 to create them. A basic version of Character Creator 3 comes free with iClone 7, but for more advanced features such as exporting to external tools then you will need Character Creator 3 Pipeline.
I'm personally not familiar with Create Studio but if it allows import of 3D characters then Character Creator 3 Pipeline will allow you to export in the industry standard FBX format. You can also export in video formats from iClone, but sadly .MOV format with transparent background is not currently supported. You can however export in Sequence Image PNG with a transparent background. Sequence Image formats can be opended in most video editors where you can compile to the video format you wish to use.
As already mentioned, you will need iClone 7 + Character Creator 3 Pipeline to get started. In addition, you may want to add some toon packs to your library. These packs come with a variety of toon morphs which can you can mix and match to create your own custom characters. A good starting point is the pack below (other toon packs are available).
https://www.reallusion.com/ContentStore/Character-Creator/Pack/3D-Cartoon-Character-Designer/default.htmlNo other plug-ins or add-ons are really required for the creation process if you plan to work exclusively with "toon" type characters. Popular plug-ins like Headshot and SkinGen are really only required if you plan to work with realistic human characters.
How long it will take to create a character will vary. For example, you could use one of the base toon characters in the pack above, make a few adjustments, and have a character ready in minutes. However, if you want a specific look, you could spend many hours tweaking every setting and morph slider to get just what you are looking for.
