Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
I have a model which uses a bump map to create some height detail. In Blender the bump map works as expected but when I apply it in iClone it does not seem to have any effect. I have tried using both a PNG and a BMP for the height map (since some channel, such as Opacity, use the Alpha channel when provided a PNG) but in neither case did the bump map seem to do anything. Here is a render from Blender. Note the front grill, hub caps, door outline and door handle... 67% of original size (was 748x443) - Click to enlarge Now look at the same model in iClone. As can be seen the (same) Bump map is applied but it does not seem to have any effect. The grill, hub cap, door and handle details are all missing. 67% of original size (was 748x443) - Click to enlarge I noticed this happening on some of my other content but I have not yet been able to determine what is causing it. Does anyone have some suggestions that I could try to get my bump map working?
Amper Sand
Amper Sand
Visits: 5.2K
Strictly for Bump map - the Strength property, but I don't think you don't checked. Also, maybe they are made for Normal, not for Bump. However, to me it looks like the prop is made by more meshes, and some of them (grill, wheel) are missing the diffuse map in the first place. You could try to experiment putting the bump into the displacement with auto-assign to bump, then try to adjust roughly displacement to see if there's any changes.
______________________________________________________________________________ Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend In progress: Black Mamba AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
Last Active: 15 hours ago
Posts: 5.3K,
Visits: 16.6K
Looks like you have ngons issue here. Mesh with ngons imported as OBJ does not look good in any app: https://forum.reallusion.com/FindPost439816.aspxMight happen after using Limited Dissolve. Try to triangulate faces before exporting from Blender and see if that makes difference (Blender being a modeling app does better job triangulating with beautify option, than 3DX).
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
ampertox (9/13/2021) Strictly for Bump map - the Strength property, but I don't think you don't checked. Also, maybe they are made for Normal, not for Bump. However, to me it looks like the prop is made by more meshes, and some of them (grill, wheel) are missing the diffuse map in the first place.The original model (in Blender) uses Bump maps not normals, so that should be correct. The model is made up of one body mesh which includes everything except for the tires. The tires are their own meshes. ampertox (9/13/2021) You could try to experiment putting the bump into the displacement with auto-assign to bump, then try to adjust roughly displacement to see if there's any changes.
Thanks. I will try that.
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
4u2ges (9/13/2021)
I will give that a try. That could also be the problem with the tire geometry not loading correctly.
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
So it turns out that part of the problem was Strength setting. I triangulated the mesh and then raised the Strength to 100%. This kicked in the bump but rather poorly compared to what I see in Blender. Looking at the comparison in the screen shots below, you can see that the Blender version had a grill that was uniform on both sides, the lettering on it was clear, the signal lights had a vertical lined texture, and the door line and handle were present. Looking at the iClone version, the grill seems to be divided into two parts (as if the normals were facing the wrong way for half the grill...which they were not), the lettering on the grill is blurry, the detailing on the signal lights is gone. Only the door outline and handle seem to be fairly well reproduced. 67% of original size (was 748x443) - Click to enlarge I have tried playing with the strength but the signal lights details never appear. I have also tried using the displacement with automatic bump setting but that also does not work. As can be seen, the Delorean is one mesh with a single material so it is not possible for the bump map to be applied to part of the mesh but not other parts. 67% of original size (was 748x443) - Click to enlarge It looks to me like the sensitivity of the RL bump map implementation is unable to pickup the subtle height differences in the bump map that Blender is able to pick up. Any other suggestions?
Posts: 5.3K,
Visits: 16.6K
Hard to suggest without having the model and texture maps. But I never had any problems with bump/normal maps in iClone (I mostly make normal maps though). Although what I see in a grill, is that mesh is smoothed. You need sharp edges. Bump map is not going to do anything there. Either try to use auto-smooth in 3DExchange, or mark grill edges sharp in Blender and apply Edge Split modifier.
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
The grill is purely bump map and the bump map has very distinct/sharp color changes.
I have to double check my theory but I think I noticed that iClone seems to be using lower resolution version of my texture maps. This would explain why the text is more blurry and why the bump map details are not sharp.
If I am not mistaken, the texture maps that I imported were 2048 x 2048 in resolution. However, when I ask iClone to edit the texture map, provides a 1024 x 1024 resolution file.
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
Posts: 15.8K,
Visits: 31.3K
The resolution of the maps should not change unless Max Texture Size is set to a lower resolution in 3DXchange during export.
