gery.hristova
gery.hristova
Visits: 651
Hello, I am currently experiencing issue: 0x00007FF678A799C2. It appears each time I have more than three objects with activated physics.  The issue has appeared every time I've tried to change the weight map of an object. It happens randomly, I am stuck and frustrated. Any suggestions will be highly appreciated. :)
Posts: 23.1K,
Visits: 36.6K
Hi... Sorry to hear you are having these problems. If you can reproduce the issue repeatedly, please either report it on in the Feedback Tracker, or if this issue is seriously affecting your use of iClone, you can contact Technical Support direct using the link below. In either case please do supply your project and the steps to reproduce the issue. We will then investigate and get back to you. Thanks. https://www.reallusion.com/CustomerSupport/UserEx/QForm.html
gery.hristova
gery.hristova
Visits: 651
Thank you Peter!
gery.hristova
gery.hristova
Visits: 651
Thank you Peter, I'll try contacting the Technical Support. The error keeps appearing and crashing the programe.
