lvanvalk
lvanvalk
Visits: 140
I am trying to open a file from the 3D Warehouse in 3DXchange but 3DXchange states: I do have the 2021 version of 3DXchange so why would I need to change it to a 2015 format and/or how do I do that? Thank you.
dogged2003
dogged2003
Visits: 4.5K
gordryd
gordryd
Visits: 7.6K
This is a limitation of 3DXchange (that needs to be fixed). One way to workaround is to download a copy of SketchUp. Open the file in SketchUp and select 'SaveAs' and then choose 'SketchUp 2015' format. You can then import into 3DX. My version of the SketchUp program is 2017 -- I don't know if current versions will still let you save in 2015 format or not?
lvanvalk
lvanvalk
Visits: 140
I will check this out. Thank you.
Last Active: 3 hours ago
Posts: 15.7K,
Visits: 30.5K
You can still download the free desktop version of SketchUp 2017. This will let you save in the SU 2015 format. See: https://help.sketchup.com/en/downloading-older-versions.
You want the desktop version, which Trimble in their greed have since dropped. All you can get now for free is some cloud-based app... You can add your support to my Feedback Tracker entry to have RL do something about it:https://www.reallusion.com/FeedBackTracker/Issue/3DXchange-should-support-newer-Sketchup-versions/
The technical explanation is that it is impossible to upgrade to 64 bit and support the latest SketchUp, but that doesn't of course help any of us
EDIT: As mentioned below, anything below 2019 is no longer supported (unless the original model is in an older format).
3 Years Ago by
Last Active: 30 minutes ago
Visits: 60.5K
Posts: 5.0K,
Visits: 15.9K
FYI Since yesterday 3D Warehouse stopped supporting anything below 2019. So pCon is the only option left.
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
another possible workaround - often the 3D warehouse models have dae versions that are much easier to convert though software like blender, daz, or the autodesk fbx converter which can convert dae to fbx
Posts: 5.0K,
Visits: 15.9K
I did not mention Collada, because unfortunately a lot of the times it comes to Blender completely messed up. I did not try other apps though. Just a random example:
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
admittedly i never tried it in blender - because blender has always been sort of a hit or a miss in importing structures with many parts, but i have had better luck with other softwares - the simple autodesk converter approach works fairly well, actually.
