johnschneider066
johnschneider066
Visits: 529
Thank you both! I learn so much from you guys. As soon as I turned iClone shader to high my model immediately turned blonde. And then I adjusted the lighting also.
Posts: 15.8K,
Visits: 31.4K
You can also load a .ccProject file into iClone by changing the extension to .iProject. That would give you the same conditions. In iClone make sure that the shader mode is set to "High". "Quick Mode" would look different.
Posts: 4.9K,
Visits: 16.7K
It's possibly that the lighting setup is different in iClone than it is in CC. You can copy the Atmosphere lighting setups from CC using the "Find File" feature to iClone (if they are not already there) and thus have the same lighting setup. That might be the issue.
johnschneider066
johnschneider066
Visits: 529
I used Character Creator and changed my female model's hair from brown to blonde. When I exported to iClone, it turned brown again. Here are the steps I took: 1) import default female character with wife's face from Headshot. 2)Using Prime Hairstyles, I chose 03_Cute braid long hair.rHair (brown hair). 3) Select 03-hair_5iMltPlus (blonde hair) 4) Apply material, leave checked Material Settings and Textures and Check Shader, Apply. 5) Modify, Material Tab, Save Material Plus. 6) Save Material Plus Option, leave all checked. 7) Save. 8) Export, send to iClone Result - Character has brown hair again. What am I doing wrong?
