mono11
mono11
Visits: 6
Hello, I am trying to move a camera in iClone (named "camera1"). Running the following script: camera = RLPy.RScene.FindObject(RLPy.EObjectType_Camera, "camera1") if not camera.IsValid(): log_label.setText("camera is not available") else: log_label.setText("camera is available")
control = camera.GetControl("Transform")
transform = RLPy.RTransform.IDENTITY transform.T().x = -75.0 transform.T().y = -150.0 transform.T().z = 250.0 time = RLPy.RTime(0) control.SetValue(time, transform) # update after adding a key camera.Update() gives me the following error:
control.SetValue(time, transform) AttributeError 'NoneType' object has no attribute 'SetValue'
What am I doing wrong? Also, can I create a camera directly from the python script? Tnx!
gordryd
gordryd
Last Active: 3 Weeks Ago
Visits: 8.1K
This code looks exactly like the sample provided by RL in the wiki (except for the if-else section). What does the console log look like? Is "camera1" 'available'? Also, the indentation looks off for the first line (maybe a result of copy/paste to the forum)
videodv
videodv
Visits: 12.0K
I tried this out and if you remove the "if else statment" and make sure camera1 is in the scene then it works fine.
import RLPy
# if not camera.IsValid(): # log_label.setText("camera is not available") # else: # log_label.setText("camera is available")
control = camera.GetControl("Transform") transform = RLPy.RTransform.IDENTITY transform.T().x = -75.0 transform.T().y = -150.0 transform.T().z = 250.0 time = RLPy.RTime(0) control.SetValue(time, transform) # update after adding a key camera.Update()
Chris.
mono11
mono11
Visits: 6
thanks chris and gordryd! yes, it is exactly the RL sample! The camera is in the scene, I double checked the name and it is set to "camera1". In fact, I get the output "camera is available" from the script. Anyway, I removed the camera and created a new one, leaving its name to the default one ("Camera") and changed the string in FindObject accordingly, and now it works :)
Btw, do you know where I can see the outputs of "print" commands? They do not show up in the Console log (this is why I had to set a label in the qtwidget to debug...)
videodv
videodv
Visits: 12.0K
The output of the print comand prints to the consol log you find this under scripts/Consol Log incase you have not seen it. This has always worked for me so not sure why its not working for you. Chris.
