DoronT770
DoronT770
Visits: 176
this is for cartoon animator not iclone (why does iclone called iclone if its not supported on Macs??)
Posts: 5.3K,
Visits: 16.8K
....... I cleared unrelated post as I just realized OP wanted it for CARTOON ANIMATOR. Sorry for the confusion :w00t::D
MilesV
MilesV
Visits: 2.2K
This is just me theorizing as I haven't experimented with anything like that.
Are you using smart hair elements for this? If that is the case, they'll only move with the bone they are attached to. You would likely need to manually animate the hair in iClone. If you're able create custom hair in a third-party tool, then apply skin weight for the hair in CC3 and add PhysX, you may be able to achieve the results you're looking for.
Edit: You may be able to find that hairstyle on daz. I did a quick search and didn't find anything, but may not be using the right search terms and there is a lot of hair to skim through on there. You may be able to find other hairstyles with a similar element and remove the unneeded hair cards in blender to achieve this result.
DoronT770
DoronT770
Visits: 176
I want to make hair that moves like a pony tail, making it with a tail is perfect but when the head turn and layers change in a 360 angle the tail doesn't. am I missing something, is there a way I don't know to make this happen? here in Israel there's a unique hairstyle where you take off all of the hair from you head beside a patch above the ears like shown here, I need to make this character and when he jumps and dance the hair should dance too :)
