Posted By Victor.Soupday 5 Years Ago
Rated 5 stars based on 12 votes.
29
30
31
32
33
58
Victor.Soupday
Victor.Soupday
Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)
Posts: 569, Visits: 9.0K
emelyjohnstone (8/1/2022)
Has this been sorted for the URP tool as I have had the same errors when trying to build?
yes.
XyrisKenn
XyrisKenn
Veteran Member (941 reputation)Veteran Member (941 reputation)Veteran Member (941 reputation)Veteran Member (941 reputation)Veteran Member (941 reputation)Veteran Member (941 reputation)Veteran Member (941 reputation)Veteran Member (941 reputation)Veteran Member (941 reputation)
Posts: 26, Visits: 464
For handling LOD conversions, I need to define the LOD manually in Unity because the models from CC are represented all at the same time. This only takes a minute to do and is not a problem.
With your fabulous converter, which has converted me to a believer :) Are LOD levels also processed? Would you recommend a particular topic to keep in mind when importing LODs?
Thank you for making this converter available.
sitesazy.com
sitesazy.com
Junior Member (248 reputation)Junior Member (248 reputation)Junior Member (248 reputation)Junior Member (248 reputation)Junior Member (248 reputation)Junior Member (248 reputation)Junior Member (248 reputation)Junior Member (248 reputation)Junior Member (248 reputation)
Posts: 9, Visits: 322
I encountered this error while importing the pluginplease guide meWhat is this error related to?error J:D:\Animation_Programs\cc_unity_tools_HDRP-1.3.5\Runtime\PhysicsSettingsStore.cs(111,19): error CS0117: 'AssetDatabase' does not contain a definition for 'SaveAssetIfDirty'https://forum.reallusion.com/uploads/images/230a1639-bd67-48d7-b161-c7cc.png
matthias.baudrexl
matthias.baudrexl
New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)
Posts: 1, Visits: 7
Hi Victor,
i cant use the tool in unity version 2020.3.6f1 with built in pipeline. I imported the package over the package manager but it didnt created a CC_Assets folder and i cannot start the import process, because there are no buttons shown when i click on my fbx character model. I am also getting console Errors. Could you please help? https://forum.reallusion.com/uploads/images/f5a7ac2c-c0c1-4b04-bbf8-99d8.png
Victor.Soupday
Victor.Soupday
So it wasn't just a 2019 problem.
The Culprit function: SaveAssetIfDirty, was added in 2021.2.0 and back-ported mid release to 2020.3.16 and 2021.1.17. And there is nothing in the API documentation to explain this. So if you had versions above that it was fine, but before that it gives compile errors.
Anyway:
HDRP fix: https://github.com/soupday/cc_unity_tools_HDRP/releases
URP fix: https://github.com/soupday/cc_unity_tools_URP/releases
3D fix: https://github.com/soupday/cc_unity_tools_3D/releases
sitesazy.com
sitesazy.com
thank you
you are best developer unity auto setup
Can you design a plugin for Livelink to Unity?
sitesazy.com
sitesazy.com
I had a request from my friend Victor.Soupday
If it is possible to make a video with Kevin, and transfer it from iClone 8 to Unity, these tutorials can help a lot, the hair and eye shaders for Kevin do not work after importing the model, the model without The compiler  shader is annoying and not good
We need video
Thank you brother
the problem attached
thank you very much brotherhttps://forum.reallusion.com/uploads/images/c863e47a-bcc4-4851-b2aa-e9ed.png
Victor.Soupday
Victor.Soupday
sitesazy.com (8/16/2022)
We need video
Thank you brother
It's not working because you're using a character that was exported for Unreal. (You can tell it's for Unreal because the object names are all lower case and the character is standing in an A-Pose.)
The Unity auto-setup package was only works for Unity exports from character creator and iClone, because the other export types use different texture packing that Unity doesn't recognise. e.g. Unreal's ORM texture packing.
Jfrog
Jfrog
Posts: 702, Visits: 4.7K
@Victor.Soupday
I have an old version of Character Creator (1.3.3) setup already installed in a previous Unity project. I successfully open the older project on Unity 2020.3.5f1 LTS without a hitch.
Can I installed the latest version of the Character creator to Unity setup to get the alembic workflow?  Should I just remove the older version using the package manager? I want to make sure my CC assets are not removed at the same time.    :)
Thanks for the help!
Horror Stories in VR
Immersive Sound VR
Victor.Soupday
Victor.Soupday
Jfrog (8/23/2022)
@Victor.Soupday
Removing the old and installing the new should work. The package system keeps it isolated from the main project and Unity keeps track of the GUIDs so it will pick up the changes in the new version.
29
30
31
32
33
58
