Posted By Victor.Soupday 4 Years Ago
Rated 5 stars based on 12 votes.
21
22
23
24
25
58
dgaban
dgaban
Junior Member (152 reputation)Junior Member (152 reputation)Junior Member (152 reputation)Junior Member (152 reputation)Junior Member (152 reputation)Junior Member (152 reputation)Junior Member (152 reputation)Junior Member (152 reputation)Junior Member (152 reputation)
Posts: 13, Visits: 71
You were right. I fixed the quality in the build and the models appear fine now.
My other issues are related to lighting, which is a huge pain in the butt to deal with.
BTW is there a better fix for the open mouth issue besides using the close mouth script? I am currently using that script but later on I plan on using a lipsync system and fear that it would not work with the close mouth script.
Jfrog
Jfrog
Posts: 702, Visits: 4.7K
@Victor.Soupday    First, Thanks again for making this amazing utility tool for Unity and helping us.
I have a question that might be out of scope but I will ask it anyway since you are the person with the most knowledge integrating CC4 with Unity.
I started using the Alembic format to export to unity because all the physics applied to cloth and hair are kept within the transfer. Of course almbic does not support the materials auto conversion.  Do you have any idea how I should approach this to get the proper materials after import.  My Alembic animation play well in the Unity timeline but my shader are pink in HDRP. Here is the picture of my export settings in Iclone 8.  Thanks a lot for your help!
Horror Stories in VR
Immersive Sound VR
Victor.Soupday
Victor.Soupday
Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)
Posts: 569, Visits: 9.0K
If you first export the character as an FBX to Unity and build the materials for that. you can use that as the source character for the materials.
Then export your Alembic animation into the same place, but using 'Split Mesh by Material'. No need to export textures with the Alembic as they will be taken from the source character export. Then you can transfer the materials from the source character to the mesh renderer objects in the Alembic.
I will see about adding a feature that detects any Alembic .abc files matching the character (say any .abc files starting with the same character name or in a particular sub-folder) and generates prefabs with the materials remapped from the source character.
(Edit: this assumes you're using the Alembic Unity package)
Victor.Soupday
Victor.Soupday
dgaban (5/31/2022)
I have a solution for that (two methods in fact) for fixing the open mouth in the animations, along with some pose correction options (shoulders, arms, legs, heels, height and hands) and facial expression blend shape retargeting. Coming soon.
Jfrog
Jfrog
@Victor.Soupday  Thanks for the quick reply
I am using the unity alembic package but I am not sure I understand how to transfer the material.
Thanks again!
Immersive Sound VR
Victor.Soupday
Victor.Soupday
Just drop them in the material slots of the mesh renderers.
Jfrog
Jfrog
I will try to find where exactly.   ;)  Thanks!
Immersive Sound VR
Jfrog
Jfrog
@Victor.Soupday   i see the material slots for the original fbx (named 15) but there is no slot for my alembic file (named 15a)
Immersive Sound VR
Jfrog
Jfrog
@Victor.Soupday   I finally found where to insert the slot.    Many thanks Victor!
Immersive Sound VR
Victor.Soupday
Victor.Soupday
Not in the alembic file itself, but when you put it in a scene you can access all the objects and mesh renderers there, then you can switch over the materials (expand the materials foldout in the mesh renderers). After that you can make a prefab from the character in the scene.
21
22
23
24
25
58
