Posted By Victor.Soupday 4 Years Ago
Rated 5 stars based on 12 votes.
Victor.Soupday
Victor.Soupday
Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)
Last Active: 4 days ago
Posts: 569, Visits: 9.0K
CC/iC Unity Tools 1.6.3
Built-in (Unity 3D): https://github.com/soupday/cc_unity_tools_3D/releases  -  ( 3D
URP
: https://github.com/soupday/cc_unity_tools_URP/releases  -  ( URP10 / URP12 / URP14 / URP17 )
HDRP
: https://github.com/soupday/cc_unity_tools_HDRP/releases  -  ( HDRP10 / HDRP12 )
Documentation
: https://soupday.github.io/cc_unity_tools/
Full install instructions here: https://soupday.github.io/cc_unity_tools/installation.html#
Changelog:
1.6.3
  • Wrinkle manager update Blend shape indices button.
  • Wrinkle system setup will look for wrinkle masks in Assets as well as packages. (If tools installed into assets and not with package manager)
  • Wrinkle system added to URP shader graph shaders.
  • Anisotropic highlights added to URP shader graph hair shaders.
  • Mesh extraction checks for duplicate blend shape names.
  • URP Amplify hair shaders support for Forward+ additional lights.
  • URP Amplify shaders recompiled for ASE-1.9.6 (Fixes URP17 issues).
  • Fix to colliders not being added with just hair physics.
  • Fix to HDRP diffusion profiles not being added in HDRP17.
1.6.2
  • URP Amplify shader fix for when there is no main light.
  • Work around to intermittent CC4 specular export issue when exporting with 'Bake diffuse maps from skin color' option (which is enabled by default now).
  • Fix to physics assignment when shared materials count does not match submesh count.
1.6.1
  • Magica Cloth 2 support for hair physics.
    • Magica Cloth and collider navigation tools added.
1.6.0
  • Fixes to root bones and physics components in LOD combiner.
  • Support for Magica Cloth 2 Physics (if present) - Cloth simulation and spring bones.
  • Collider Manager rebuild to support magica cloth
    • Collider editor now uses direct on screen manipulation of colliders.
  • Support for Json Schema 1.2
    • A bug in CC4 can cause the character to export with this schema.
  • Run time wrinkle material fix.
1.5.2
  • Animation Retargeter fixes.
    • AnimationMode removed.
    • Clip generation file name suffix corrected.
    • Animation Clip overwrite no longer breaks references.
    • Clip settings (foot IK, mirror, speed) reset to defaults on opening retarget window.
  • Character prefab generation no longer breaks references. (Except 2023.1.1-5 due to Unity bugs)
  • Rogue usings removed from code.
  • Animation processing fixes.
    • Correct character prefab used to retarget _motion.fbx files.
1.5.1
  • Character Build no longer creates and adds a default animation controller due to bugs in Unity 2022/2023 causing memory leaks when applying animation controllers to prefabs.
  • Instalod and other renamed object/material name matching improvements.
  • Cloth physics fix for extracted non physics materials using 2-pass hair.
  • Shaders recompiled for URP10/12/15.
1.5.0
  • Animation player system rebuilt to remove AnimationMode and operate in play mode (in Editor).
    • New system includes foot IK preview, variable speed and camera bone targeting and play mode operation.
  • Optional (WIP) HDRP dual specular shader added for HQ skin. (Enabled in the import window options)
  • HDRP mask detail mask correction. (Export from CC4 not using correct micro normal mask)
  • HDRP lighting fix when first loading preview scene.
  • Batch processing window added.
  • Physics sphere collider support added.
  • Import procedure now processes all <character_name>_Motion.Fbx files with the character.
  • Fix to character build crash in Unity 2023.1
  • Fix to Diffusion profiles not saving to default volume asset in 2023.1.
1.4.9
  • Refresh button fix...
1.4.8
  • Fix to missing materials in shared material slots.
  • Fix to two pass hair extraction when re-using the same material.
  • Fix to hair mesh extraction when hair and non-hair materials share vertices.
  • Support for updated spring rigs from blender tools add-on.
  • Improved PhysX weight mapping from mesh to cloth vertices.
  • Added refresh button to importer window when no characters detected.
1.4.7
  • Brow correction added to wrinkle map system.
  • Wrinkle sets additive blending.
  • Wrinkle Manager configuration serialized, to allow for further customization.
1.4.6
  • Added ray tracing settings to preview scene lights.
  • Fix to HDRP diffusion profiles not setting up in HDRP14 (2022.2)
1.4.5
  • Flow maps added to wrinkle map system.
  • URP & 3D shader pass and recompile.
  • URP & 3D Baked wrinkle maps normal fix.
  • HDRP Preview scene lighting update (to replicate some CC4 atmosphere setups)
1.4.4.1
  • URP12 Shader flag pass & enable deferred rendering.
1.4.4
  • Full wrinkle map specification implemented.
    • Wrinkle map manager controls script on body mesh.
    • Added baking of wrinkle map system.
  • Spring Bone (Dynamic Bone) Hair physics, currently set up from Blender pipeline exports.
  • Import blend shape normals settings fixes.
  • Gamebase and PBR, SSS and smoothness adjustments.
  • Hair specular tint based on root + tip color.
  • Fix to bake not working with 2 pass hair materials.
  • Color space correction directives for baking.
1.4.3
  • Tries to untangle instalod duplication suffixes on accessories.
    • inc. Script error fix that was blocking build materials when instalod meshes were not found in Json data.
  • Cast shadows removed from Tearline, Eye occlusion and scalp meshes.
  • Stand alone shader packages for the various pipelines included in /Packages/ folder.
1.4.2
  • OSX and Linux file path support.
  • Tweaked character model importer settings for better normal import and blend shape normal generation. Should reduce mesh smoothing issues.
  • Disabled Menu Mesh Tools when not working on a generated prefab. (The tools cannot operate directly on an FBX)
  • Fixed Bake not replacing materials with baked versions.
  • Eye Occlusion shaders factor in Occlusion Color alpha value.
1.4.1
  • Traditional material glossiness fix.
  • High poly (sub-division) hair mesh extraction fix.
  • SSS Diffusion profile added.
  • Remembers last used lighting preset on character preview change.
  • Character icon list side bar can be dragged into a more compact list view.
    • Character list sorted alphabetically.
  • When HDRP Ray tracing is enabled:
    • The material build function will turn off ray tracing on the Scalp (when separeated), Eye Occlusion and Tearline meshes as it causes darkening artifacts on the underlying skin and eye surfaces.
    • (Typically the scalp is only separated from the hair materials when two-pass hair is enabled)
  • Bake Hair function now only bakes the result of the 'Enable Color' properties into the diffuse maps of the hair materials. Press again to revert to original diffuse maps.
  • Improved ActorCore and ActorBuild single material detection.
1.4.0
  • Import & Setup
    • ActorBuild detection separated from ActorCore (ActorBuild can have more advanced materials)
    • Fix to Instalod merged material characters detection.
    • Better detection of non-standard characters.
      • Rig animation type override (Humanoid / Generic) for non-standard characters.
    • Bone LOD characters reduced skeleton avatar generation fixed.
    • Animation player chooses from available animations when none found in character.
    • Blender to Unity imports fix for bounding box root bone issue.
    • Character Tree view shows all child renderer meshes regardless of depth.
  • Materials & Shaders
    • Lit SSS shader added for URP and 3D pipelines.
    • SSS material support added.
    • Traditional material support added.
    • Shader properties arrangement pass.
    • Material setup fix for non character objects (e.g. props from iClone)
    • Additional missing texture checks added to character bake function.
    • Amplify shaders recompiled with ASE 1.9.1.2.
    • Limbus dark ring corrected, iris should look brighter, clearer and less fuzzy at the edges.
  • Other
    • LOD combining function added.
      • Characters and LOD variants must be in same folder.
  • New icons added.
  • To maintain consistency across Unity versions, the HDRP package will be split into 2 versions:
    • HDRP10 for the High Definition Render Pipeline version 10 and 11: Unity 2020.3 upto 2021.1
    • HDRP12 for the High Definition Render Pipeline version 12 and 13: Unity 2021.2 upwards.
Threaded View
Threaded View
Forum Post Unity Auto Setup By Victor.Soupday ( 4 Years Ago )
Forum Post As shown in this thread , a WIP demo of the shaders:... By Victor.Soupday ( 4 Years Ago )
Forum Post I've been improving the Eye Occlusion and Tearline shader: Here... By Victor.Soupday ( 4 Years Ago )
Forum Post Skin micro roughness/smoothness and subsurface scatter masking.... By Victor.Soupday ( 4 Years Ago )
Forum Post Interesting! I always thought those masks had something to do with... By merph ( 4 Years Ago )
Forum Post [quote][b]merph (7/12/2021)[/b][hr]Interesting! I always thought those... By Victor.Soupday ( 4 Years Ago )
Forum Post Wow! this is awesome and super helpful, let me ask a probably dumb... By Angel Valtierra ( 3 Years Ago )
Forum Post You don't need to change the materials, there are custom shaders to... By Victor.Soupday ( 3 Years Ago )
Forum Post [quote][b]Victor.Soupday (7/11/2021)[/b][hr]As shown in this thread ,... By Rowlan09 ( 4 Years Ago )
Forum Post Victor, I must say, you do know shaders. Impressive. I'm just a... By animagic ( 4 Years Ago )
Forum Post [quote][b]animagic (7/12/2021)[/b][hr]Victor, I must say, you do know... By Victor.Soupday ( 4 Years Ago )
Forum Post This looks amazing but I'm afraid that for games, having characters... By Necka ( 4 Years Ago )
Forum Post [quote][b]Necka (7/12/2021)[/b][hr]This looks amazing but I'm afraid... By Victor.Soupday ( 4 Years Ago )
Forum Post [quote][b]Victor.Soupday (7/13/2021)[/b][hr][quote][b]Necka... By Necka ( 4 Years Ago )
Forum Post It works with the merged materials output from InstaLod. The remesher,... By Victor.Soupday ( 4 Years Ago )
Forum Post looks good By chrisabranch_505463 ( 4 Years Ago )
Forum Post Hi, Any possible date you can give for the HDRP Auto setup 2020,3... By kvergot ( 4 Years Ago )
Forum Post That is some great work, and would truly be interested in seeing what... By deidrereaystudios ( 4 Years Ago )
Forum Post Update : I've tested it with what I've got, and whilst I'm not 100%... By Victor.Soupday ( 4 Years Ago )
Forum Post Notes : Hair shader : In order to resolve z-sorting issues with... By Victor.Soupday ( 4 Years Ago )
Forum Post Thank you so much for this, great work. By e.l.thomas ( 4 Years Ago )
Forum Post I was pretty excited to try this out today, even though I had to wait... By tantrum ( 4 Years Ago )
Forum Post [quote][b]tantrum (7/27/2021)[/b][hr]I've yet to fathom or compare the... By Victor.Soupday ( 4 Years Ago )
Forum Post [quote][b]tantrum (7/27/2021)[/b][hr]I don't know if anything can be... By Victor.Soupday ( 4 Years Ago )
Forum Post [quote][b]Victor.Soupday (7/27/2021)[/b][hr] So I got to thinking: The... By Necka ( 4 Years Ago )
Forum Post I have a feeling some of that is down to the strong anti-aliasing in... By Victor.Soupday ( 4 Years Ago )
Forum Post Just wanted to say, Victor.Soupday - you're doing a fantastic job.... By cly3d ( 4 Years Ago )
Forum Post [quote][b]cly3d (7/27/2021)[/b][hr]Could you expose sliders for... By Victor.Soupday ( 4 Years Ago )
Forum Post Oh! Beautiful! Thanks so much for the advice on this. By cly3d ( 4 Years Ago )
Forum Post [quote][b]Victor.Soupday (7/28/2021)[/b][hr]Unfortunately the Unity... By Necka ( 4 Years Ago )
Forum Post One of the first things I noticed is something clipping in the eye... By tantrum ( 4 Years Ago )
Forum Post [quote][b]tantrum (7/27/2021)[/b][hr]One of the first things I noticed... By Victor.Soupday ( 4 Years Ago )
Forum Post EDIT: Opened an issue directly on GitHub to avoid spam By Necka ( 4 Years Ago )
Forum Post v 0.1.3 Normal strength settings for all relevant custom... By Victor.Soupday ( 4 Years Ago )
Forum Post Holy Shit! Pay this guy reallusion. He has made cc3 characters... By mikekan13 ( 4 Years Ago )
Forum Post Is there a way to enable tesselation and displacement maps yet? By mikekan13 ( 4 Years Ago )
Forum Post Per the previous page, have you tried this (bake and then use... By tantrum ( 4 Years Ago )
Forum Post Fantastic! Thank you. By mikekan13 ( 4 Years Ago )
Forum Post Just had a go - image is from within Unity - Brand New to reallusion... By sirsquish ( 4 Years Ago )
Forum Post The results are impressive. I'm running into a problem with lip sync.... By Dan Miller ( 4 Years Ago )
Forum Post [quote][b]danmiller (8/1/2021)[/b][hr] The results are impressive. I'm... By Victor.Soupday ( 4 Years Ago )
Forum Post [quote]Are you starting the audio as soon as you hit play? You need to... By Dan Miller ( 4 Years Ago )
Forum Post Other than starting it from a script, you could start with the... By Victor.Soupday ( 4 Years Ago )
Forum Post Sounds good, thanks. By Dan Miller ( 4 Years Ago )
Forum Post Issueand possible solution here (not able to test myself at the... By jonnys777 ( 4 Years Ago )
Forum Post Are you getting it like the other thread images showed? I was... By tantrum ( 4 Years Ago )
Forum Post It's very green. I'm in linear color space. The fixes in that thread... By jonnys777 ( 4 Years Ago )
Forum Post The default HDRP/Lit shaders can turn the character skin green if... By Victor.Soupday ( 4 Years Ago )
Forum Post Thanks Victor. It was a normal export. Used the settings described... By jonnys777 ( 4 Years Ago )
Forum Post I made a new test project in an updated version of Unity. My only... By jonnys777 ( 4 Years Ago )
Forum Post I think I may be relying on demo assets for the skin diffusion... By Victor.Soupday ( 4 Years Ago )
Forum Post Thanks again Victor - those fixes worked. For benefit of others - I... By jonnys777 ( 4 Years Ago )
Forum Post Do the pupils dilate base on light with your shaders? When I first... By mikekan13 ( 4 Years Ago )
Forum Post This is the second (and completely unrelated to eachother) asset I've... By tantrum ( 4 Years Ago )
Forum Post @tantrum 2021.2.0b7 and 2020.3.16f1 Seems that 0.17 solved the issue... By vlastan ( 4 Years Ago )
Forum Post Sorry - 0.17? Did you mean 2021.1.17f1 ? By tantrum ( 4 Years Ago )
Forum Post @tantrum 0.17 is the latest CC3 unity tools release, the one which... By vlastan ( 4 Years Ago )
Forum Post Ohh, ok got it. I reference it as 0.1.7 so it threw me off :) Thanks... By tantrum ( 4 Years Ago )
Forum Post Finally a better tool for cc3 character import to Unity. Thank you... By vlastan ( 4 Years Ago )
Forum Post Update version 0.1.6... By Victor.Soupday ( 4 Years Ago )
Forum Post Confirming that the build errors have been fixed with this latest... By jonnys777 ( 4 Years Ago )
Forum Post Victor, i am having memory related problems with the tool in my... By vlastan ( 4 Years Ago )
Forum Post Ok, I've gone through the importer code and made some changes to... By Victor.Soupday ( 4 Years Ago )
Forum Post @Victor.Soupday The work you're doing is inspirational. I've been... By cly3d ( 4 Years Ago )
Forum Post Two things I've come across: - If baking the shader so as to then use... By cly3d ( 4 Years Ago )
Forum Post [quote][b]cly3d (8/28/2021)[/b][hr]Two things I've come across: - If... By Victor.Soupday ( 4 Years Ago )
Forum Post Thanks Victor. I has a hunch some things might not yet be supported... By cly3d ( 4 Years Ago )
Forum Post [quote][b]cly3d (8/28/2021)[/b][hr]Would it be possible at all, to... By Victor.Soupday ( 4 Years Ago )
Forum Post Hey, thanks for the tool. I'm having some trouble with getting... By Sovo ( 4 Years Ago )
Forum Post [quote][b]Sovo (9/3/2021)[/b][hr]What I notice is that the CC3... By Victor.Soupday ( 4 Years Ago )
Forum Post Thank you. I will investigate tonight and report back. I have to say... By Sovo ( 4 Years Ago )
Forum Post Here's the results using a comparison of a Character Creator default... By Sovo ( 4 Years Ago )
Forum Post [quote][b]Sovo (9/7/2021)[/b][hr]Here's the results using a comparison... By Victor.Soupday ( 4 Years Ago )
Forum Post Hi. Originally I had the animation within the YBot fbx. However, I... By Sovo ( 4 Years Ago )
Forum Post The Avatars describe how the bones in the FBX map to the equivalent... By Victor.Soupday ( 4 Years Ago )
Forum Post Yes, that did it indeed. I tried setting the IK pass on the layer,... By Sovo ( 4 Years Ago )
Forum Post Hi, do you plan to add InstaLODs support? Currently If I export CC3+... By tm_863950 ( 4 Years Ago )
Forum Post [quote][b]tm_863950 (9/14/2021)[/b][hr]Hi, do you plan to add... By Victor.Soupday ( 4 Years Ago )
Forum Post Release: v 0.1.8 After applying materials or baking materials in... By Victor.Soupday ( 4 Years Ago )
Forum Post @victor.soupday Hi Victor, First, thank you for the great work you've... By Jfrog ( 4 Years Ago )
Forum Post [quote][b]Jfrog (10/1/2021)[/b][hr]@victor.soupday Hi Victor, First,... By Victor.Soupday ( 4 Years Ago )
Forum Post Hello, I downloaded the auto setup for unity and I'm trying to import... By patkutka ( 4 Years Ago )
Forum Post [quote][b]patkutka (10/2/2021)[/b][hr]Hello, I downloaded the auto... By Victor.Soupday ( 4 Years Ago )
Forum Post Oh my god, I'm so sorry! I installed this (... By patkutka ( 4 Years Ago )
Forum Post Hi all! Finally diving into this amazing tool. Just phenomenal work. I... By Enigma Factory ( 4 Years Ago )
Forum Post [quote][b]Enigma Factory (10/5/2021)[/b][hr]Hi all! Finally diving... By Victor.Soupday ( 4 Years Ago )
Forum Post @Victor.SoupDay [quote]Do you have enough bones affecting the skin... By Jfrog ( 4 Years Ago )
Forum Post Thanks so much Victor! The texture I have by that name was in my... By Enigma Factory ( 4 Years Ago )
Forum Post I didn't know this exist. I think i have been using/trying the wrong... By habban ( 4 Years Ago )
Forum Post Hi, I'm highly interested in this auto setup tool for Unity,... By antoine.ober ( 4 Years Ago )
Forum Post [quote][b]antoine.ober (10/17/2021)[/b][hr]Hi, I'm highly interested... By Victor.Soupday ( 4 Years Ago )
Forum Post Just can't wait for this! Thanks @ Victor.Soupday By jerome.dipietro ( 4 Years Ago )
Forum Post Thanks for the feedbacks. The hair you made on these 3 pics are... By antoine.ober ( 4 Years Ago )
Forum Post When will we see support for Unity and URP? It seems that Reallusion's... By digitallywired ( 4 Years Ago )
Forum Post If you don't mind testing an unstable dev version, you can try the URP... By Victor.Soupday ( 4 Years Ago )
Forum Post Thanks ! May be helpful for others, but unfortunately my project is on... By antoine.ober ( 4 Years Ago )
Forum Post Is there a Plan for the built in pipeline at all? Reading through have... By deidrereaystudios ( 4 Years Ago )
Forum Post Go back 7 posts in this thread, it was mentioned there By tantrum ( 4 Years Ago )
Forum Post The built-in pipeline has been a little different as it requires the... By Victor.Soupday ( 4 Years Ago )
Forum Post @ Victor.Soupday Love the two pass shader rendering for the hair!... By jerome.dipietro ( 4 Years Ago )
Forum Post Built-in Render Pipeline So here is the initial pre-release of the... By Victor.Soupday ( 4 Years Ago )
Forum Post Fantastic ! Thank you so much ! :D I'll download your tool and I'll... By antoine.ober ( 4 Years Ago )
Forum Post Thank you. I didn't know what I was missing until your build-in... By wetcircuit ( 4 Years Ago )
Forum Post Hum, all this is pretty new to me, so it may be a stupid question, I'm... By antoine.ober ( 4 Years Ago )
Forum Post You don't appear to have a textures folder for that character. Each... By Victor.Soupday ( 4 Years Ago )
Forum Post Yeah indeed, all the textures are inside the .fbm folder, like that :... By antoine.ober ( 4 Years Ago )
Forum Post The file structure as exported by CC3 needs to kept exactly intact,... By Victor.Soupday ( 4 Years Ago )
Forum Post Got it ! I exported it again (ticking on the "embed texture"), then... By antoine.ober ( 4 Years Ago )
Forum Post Don't embed textures. Never embed textures. By Victor.Soupday ( 4 Years Ago )
Forum Post Oh ok, I didn't know it was a trap, haha. Anyway, I finally made it !... By antoine.ober ( 4 Years Ago )
Forum Post [quote][b]antoine.ober (10/27/2021)[/b][hr] [/quote] The normals... By Victor.Soupday ( 4 Years Ago )
Forum Post Yeah indeed, I reduced the Normal strength inside Unity, and it looked... By antoine.ober ( 4 Years Ago )
Forum Post I also noticed that when the character is in a dark place, all the... By antoine.ober ( 4 Years Ago )
Forum Post [quote][b]antoine.ober (10/28/2021)[/b][hr]I also noticed that when... By Victor.Soupday ( 4 Years Ago )
Forum Post Hair in Built in Pipeline is a pain... Interested to see what you can... By deidrereaystudios ( 4 Years Ago )
Forum Post [quote][b]deidrereaystudios (10/29/2021)[/b][hr]Hair in Built in... By Victor.Soupday ( 4 Years Ago )
Forum Post Is that new hair shader uploaded to the Git? Would like to take a look... By deidrereaystudios ( 4 Years Ago )
Forum Post There are already tutorials videos, documentation (see above) and... By antoine.ober ( 4 Years Ago )
Forum Post Using the Built In Pipeline and brought in through package manager as... By deidrereaystudios ( 4 Years Ago )
Forum Post Actually you must put the tool outside your project, not in Assets or... By antoine.ober ( 4 Years Ago )
Forum Post [quote]"'file:' dependency [com.soupday.cc3_unity_tools] was not... By Victor.Soupday ( 4 Years Ago )
Forum Post Yeah, I've seen this Documentation, but indeed I shouldn't put the... By antoine.ober ( 4 Years Ago )
Forum Post Unity Auto-setup Release 0.2.0 Build-in (Unity 3D):... By Victor.Soupday ( 4 Years Ago )
Forum Post Some notes about the 2-pass hair material system. Recreating a... By Victor.Soupday ( 4 Years Ago )
Forum Post That is so great, Testing a bit with it now (Built in 2020.3 LTS) am a... By deidrereaystudios ( 4 Years Ago )
Forum Post It doesn't make any difference for the built-in shader as the default... By Victor.Soupday ( 4 Years Ago )
Forum Post Maybe something like that. Been testing all morning with some good... By deidrereaystudios ( 4 Years Ago )
Forum Post [quote][b]deidrereaystudios (10/31/2021)[/b][hr]Maybe something like... By Victor.Soupday ( 4 Years Ago )
Forum Post @ Victor.Soupday just started trying out the URP version. Some... By jerome.dipietro ( 4 Years Ago )
Forum Post Currently I am using Unity 2019.4LTS for one of my project(HDRP). What... By dassoubarna ( 4 Years Ago )
Forum Post My versions start at 2020.3 LTS. I had to draw the line somewhere,... By Victor.Soupday ( 4 Years Ago )
Forum Post Thanks a lot. By dassoubarna ( 4 Years Ago )
Forum Post @ Victor.Soupday I try to use your latest release in a 3D project of... By dassoubarna ( 4 Years Ago )
Forum Post [quote][b]dassoubarna (11/16/2021)[/b][hr]@ Victor.Soupday I try to... By Sifr ( 4 Years Ago )
Forum Post Humanoid rig is now selectable, it wasn't in the previous version just... By Sifr ( 4 Years Ago )
Forum Post [quote][b]Sifr (11/15/2021)[/b][hr]Humanoid rig is now selectable, it... By Victor.Soupday ( 4 Years Ago )
Forum Post [quote][b]Victor.Soupday (11/17/2021)[/b][hr][quote][b]Sifr... By Sifr ( 4 Years Ago )
Forum Post @ Victor.Soupday Is Sub Surface Scattering is available in any... By dassoubarna ( 4 Years Ago )
Forum Post There's subsurface scattering in the HDRP version. Haven't quite... By Victor.Soupday ( 4 Years Ago )
Forum Post Thanks for the information. By dassoubarna ( 4 Years Ago )
Forum Post Hi Soup, Thank you very much for this fantastic plugin your a legend.... By GamesAlchemist ( 4 Years Ago )
Forum Post Game base eyes are just simple PBR materials, there's nothing special... By Victor.Soupday ( 4 Years Ago )
Forum Post Hello and thank you for all your effort with CC3 and Unity. I have... By chadfranklin47 ( 4 Years Ago )
Forum Post @ chadfranklin47 Have you generated/regenerated the lighting from the... By Victor.Soupday ( 4 Years Ago )
Forum Post Edit: sorry for such a long post, but I wanted to give as much info as... By chadfranklin47 ( 4 Years Ago )
Forum Post [quote][b]chadfranklin47 (12/3/2021)[/b][hr]Screenshot 8 with RTXGI:... By Victor.Soupday ( 4 Years Ago )
Forum Post Thanks for all the help. I'm not sure of a setting that limits the... By chadfranklin47 ( 4 Years Ago )
Forum Post This may explain why the hair and eyes are not cooperating well with... By Victor.Soupday ( 4 Years Ago )
Forum Post Thank you very much for the response, I spent the day messing around... By GamesAlchemist ( 4 Years Ago )
Forum Post [quote][b]tobias_959505 (12/3/2021)[/b][hr]My main concern now is the... By Victor.Soupday ( 4 Years Ago )
Forum Post Does this work with InstaLod? If so what settings are needed on CC3... By mikekan13 ( 4 Years Ago )
Forum Post [quote][b]mikekan13 (12/3/2021)[/b][hr]Does this work with InstaLod?... By Victor.Soupday ( 4 Years Ago )
Forum Post Also want to report another issue I found with the eye shader corner... By chadfranklin47 ( 4 Years Ago )
Forum Post Hi Victor sorry to bother you but I'm having issues with the cc3 hair... By GamesAlchemist ( 4 Years Ago )
Forum Post What could cause the beard to be lit when the point light is behind... By CCUnityUser ( 4 Years Ago )
Forum Post @ Victor.Soupday when I export an character with talking animation... By dassoubarna ( 4 Years Ago )
Forum Post It's been a while, so I thought I would share some of the things I... By Victor.Soupday ( 3 Years Ago )
Forum Post [quote][b]Victor.Soupday (2/1/2022)[/b][hr]Ihat's it for now. There's... By jerome.dipietro ( 3 Years Ago )
Forum Post [quote][b]jerome.dipietro (2/1/2022)[/b][hr][quote][b]Victor.Soupday... By Victor.Soupday ( 3 Years Ago )
Forum Post New stuff looks fantastic 👏 By K.m.burgess ( 3 Years Ago )
Forum Post Fantastic work Victor, looking forward to the next URP release! By tamulur ( 3 Years Ago )
Forum Post Thank you so much Victor for your hard work. This is very appreciated!... By Jfrog ( 3 Years Ago )
Forum Post @victor.Soupday Edit: forget about it my mistake problem solved! Is... By Jfrog ( 3 Years Ago )
Forum Post 2020.3 is the version they're all primarily developed in. If it can't... By Victor.Soupday ( 3 Years Ago )
Forum Post Thanks for the super quick reply Victor. I am not sure what happened... By Jfrog ( 3 Years Ago )
Forum Post Just made of few tests .The textures and materials are awesome. The... By Jfrog ( 3 Years Ago )
Forum Post Hi! And thank you for your development. Are there an 2022 version for... By Sekker2k4 ( 3 Years Ago )
Forum Post [quote][b]Sekker2k4 (2/18/2022)[/b][hr]Hi! And thank you for your... By Victor.Soupday ( 3 Years Ago )
Forum Post I see that with the 3D pipeline, you recommend also using the post... By thubbard ( 3 Years Ago )
Forum Post Any screen space effect (e.g. post processing) is heavy in VR, and... By jerome.dipietro ( 3 Years Ago )
Forum Post Unity Auto-setup Release 1.1.1 Built-in (Unity 3D):... By Victor.Soupday ( 3 Years Ago )
Forum Post This update brings all the pipelines up to date to reproduce the... By Victor.Soupday ( 3 Years Ago )
Forum Post Unity Auto-setup Release 1.2.0 Built-in (Unity 3D):... By Victor.Soupday ( 3 Years Ago )
Forum Post Hi Victor, what an amazing job. Is it possible to use this... By FabricioAlencar ( 3 Years Ago )
Forum Post In the past I've used FaceIt (Blender Add-On) to add the missing ARKit... By jerome.dipietro ( 3 Years Ago )
Forum Post This Face It tool is very interesting. It would be amazing to be... By FabricioAlencar ( 3 Years Ago )
Forum Post Hi. I'm locked to Unity 2019.4.11f1's built-in pipeline which this... By syver.lauritzsen ( 3 Years Ago )
Forum Post [quote][b]syver.lauritzsen (3/28/2022)[/b][hr]Hi. I'm locked to Unity... By Victor.Soupday ( 3 Years Ago )
Forum Post I have strange problem: when I import model in unity it has strange... By Makumba666 ( 3 Years Ago )
Forum Post [quote][b]Makumba666 (3/31/2022)[/b][hr]I have strange problem: when I... By Victor.Soupday ( 3 Years Ago )
Forum Post Victor.Soupday, Thanks for tips, they work. By Makumba666 ( 3 Years Ago )
Forum Post Hi @ Victor.Soupday Not sure if I'm missing something but I can't... By jerome.dipietro ( 3 Years Ago )
Forum Post [quote][b]jerome.dipietro (4/4/2022)[/b][hr]Hi @ Victor.Soupday Not... By Victor.Soupday ( 3 Years Ago )
Forum Post Thanks, that clarifies quite a bit. For understanding, are you saying... By tamulur ( 3 Years Ago )
Forum Post HI, I have a pb, or some bad project configuration -URP- : my... By babyfoothero ( 3 Years Ago )
Forum Post [quote][b]babyfoothero (4/5/2022)[/b][hr]HI, I have a pb, or some... By Victor.Soupday ( 3 Years Ago )
Forum Post Thanks @ Victor.Soupday Sorry, yes, I did indeed mean 'Build... By jerome.dipietro ( 3 Years Ago )
Forum Post The high quality materials use all the extra texture masks and colour... By Victor.Soupday ( 3 Years Ago )
Forum Post Thanks for your patience @ Victor.Soupday What threw me was the... By jerome.dipietro ( 3 Years Ago )
Forum Post Great Work! I am not a Blender user. But it will be amazing if there... By Sekker2k4 ( 3 Years Ago )
Forum Post This is a quick note to say thank you for this Auto Import script.... By jason_770227 ( 3 Years Ago )
Forum Post Hello, For me it's not working, dose anyone know what i am missing?... By EdwS ( 3 Years Ago )
Forum Post @ Victor.Soupday First off thank you for all the work you put in.... By tom.timothy ( 3 Years Ago )
Forum Post [quote][b]tom.timothy (5/15/2022)[/b][hr] @ Victor.Soupday First... By Victor.Soupday ( 3 Years Ago )
Forum Post yeah looks the same ill test it in the morning. trying really hard not... By tom.timothy ( 3 Years Ago )
Forum Post thanks for the plugin, just wondering is there anything you can do... By kristof.van.rooy ( 3 Years Ago )
Forum Post [quote][b]kristof.van.rooy (5/15/2022)[/b][hr] thanks for the plugin,... By Victor.Soupday ( 3 Years Ago )
Forum Post Thanks for the reply, it seems just with this characters clothes and... By kristof.van.rooy ( 3 Years Ago )
Forum Post HDRP version updated to fix SSS problems: CC/iC Unity Tools HDRP :... By Victor.Soupday ( 3 Years Ago )
Forum Post Hi, thanks you for update the plugin works, but i see those warnings... By babyfoothero ( 3 Years Ago )
Forum Post That's what the "delete hidden faces" export option is for. You can... By Victor.Soupday ( 3 Years Ago )
Forum Post This tool seems great but it keeps deleting all of my assets in the... By dgaban ( 3 Years Ago )
Forum Post My version of the tool doesn't use or care about the CC Assets folder.... By Victor.Soupday ( 3 Years Ago )
Forum Post Thanks. Do you know how to remove the official tool from a project? By dgaban ( 3 Years Ago )
Forum Post Deleting: Editor/RLEditor.cs Editor/RLEditorwindow.cs Should... By Victor.Soupday ( 3 Years Ago )
Forum Post Hello, Need Help! I hope this the right place. Hope you all are... By theelflockeducator ( 3 Years Ago )
Forum Post RE: Unity Auto Setup By theelflockeducator ( 3 Years Ago )
Forum Post The animation works in the inspector but cannot get it to work on the... By theelflockeducator ( 3 Years Ago )
Forum Post Like the previous user, that's not actually my version of the setup... By Victor.Soupday ( 3 Years Ago )
Forum Post Thank you for replying. It is in the prefab folder. It seems to be... By theelflockeducator ( 3 Years Ago )
Forum Post Further to that: I see what the problem is now: ActorBuild and... By Victor.Soupday ( 3 Years Ago )
Forum Post Unity Auto-setup Release 1.2.3 Built-in (Unity 3D):... By Victor.Soupday ( 3 Years Ago )
Forum Post Hello Victor, Hope you are doing well. I thank you for all the info... By theelflockeducator ( 3 Years Ago )
Forum Post Not sure I understand what Image target is for. If you have a... By Victor.Soupday ( 3 Years Ago )
Forum Post Victor, Thank you. I have the animation looping and I will look... By theelflockeducator ( 3 Years Ago )
Forum Post @Victor.Soupday Hi Victor, I tried the latest HDRP 1.2.3 version but... By Jfrog ( 3 Years Ago )
Forum Post [quote][b]Jfrog (5/26/2022)[/b][hr]@Victor.Soupday Hi Victor, I tried... By Victor.Soupday ( 3 Years Ago )
Forum Post @Victor.Soupday Thank you so much for the quick reply. You were... By Jfrog ( 3 Years Ago )
Forum Post Got a question since i'm a bit of a noob, The models look great with... By dgaban ( 3 Years Ago )
Forum Post What platform are you building for and at what quality level? A low... By Victor.Soupday ( 3 Years Ago )
Forum Post You were right. I fixed the quality in the build and the models appear... By dgaban ( 3 Years Ago )
Forum Post [quote][b]dgaban (5/31/2022)[/b][hr]BTW is there a better fix for the... By Victor.Soupday ( 3 Years Ago )
Forum Post @Victor.Soupday First, Thanks again for making this amazing utility... By Jfrog ( 3 Years Ago )
Forum Post If you first export the character as an FBX to Unity and build the... By Victor.Soupday ( 3 Years Ago )
Forum Post @Victor.Soupday Thanks for the quick reply [quote]Then you can... By Jfrog ( 3 Years Ago )
Forum Post Just drop them in the material slots of the mesh renderers. By Victor.Soupday ( 3 Years Ago )
Forum Post I will try to find where exactly. ;) Thanks! By Jfrog ( 3 Years Ago )
Forum Post @Victor.Soupday i see the material slots for the original fbx (named... By Jfrog ( 3 Years Ago )
Forum Post @Victor.Soupday I finally found where to insert the slot. Many... By Jfrog ( 3 Years Ago )
Forum Post Not in the alembic file itself, but when you put it in a scene you can... By Victor.Soupday ( 3 Years Ago )
Forum Post Yes it works great! Thank you so much! [quote]I will see about... By Jfrog ( 3 Years Ago )
Forum Post Unity Auto-setup Release 1.3.1 Built-in (Unity 3D):... By Victor.Soupday ( 3 Years Ago )
Forum Post @VictorSoupday [quote]Alembic material setup feature added. (Unity... By Jfrog ( 3 Years Ago )
Forum Post This might be a general CC4 issue but I've noticed that certain... By dgaban ( 3 Years Ago )
Forum Post I've not used CC4 but I expect it's much like CC3. Make sure you check... By jerome.dipietro ( 3 Years Ago )
Forum Post [quote][b]jerome.dipietro (6/6/2022)[/b][hr]I've not used CC4 but I... By dgaban ( 3 Years Ago )
Forum Post [quote][b]dgaban (6/6/2022)[/b][hr][quote][b]jerome.dipietro... By sirsquish ( 3 Years Ago )
Forum Post I guess it could be a CC4 teething problem. As I said,. I don't yet... By jerome.dipietro ( 3 Years Ago )
Forum Post [q By sirsquish ( 3 Years Ago )
Forum Post [ By sirsquish ( 3 Years Ago )
Forum Post Delete these posts please By sirsquish ( 3 Years Ago )
Forum Post For some reason it posted the same message 5 times and I can't delete... By sirsquish ( 3 Years Ago )
Forum Post The Close Jaw option is great. I read somewhere that you can tick a... By Irrgeist ( 3 Years Ago )
Forum Post Hello Victor.Soupday, First of all thank you for your contributions... By paul.vanderlaan ( 3 Years Ago )
Forum Post [quote]However, in your documentation about fixing blendshapes for... By Victor.Soupday ( 3 Years Ago )
Forum Post [quote][b]Victor.Soupday (6/7/2022)[/b][hr][quote]However, in your... By paul.vanderlaan ( 3 Years Ago )
Forum Post [quote][b]paul.vanderlaan (6/9/2022)[/b][hr][quote][b]Victor.Soupday... By paul.vanderlaan ( 3 Years Ago )
Forum Post The problem has been it wasn't taking the facial profile of the... By Victor.Soupday ( 3 Years Ago )
Forum Post @Victor.Soupday Is it possible to know if the latest version of this... By Jfrog ( 3 Years Ago )
Forum Post [quote][b]Jfrog (6/21/2022)[/b][hr]@Victor.Soupday Is it possible to... By Victor.Soupday ( 3 Years Ago )
Forum Post Thanks for the quick reply and info Victor. No bones is no problem.... By Jfrog ( 3 Years Ago )
Forum Post Notepad will do: By Victor.Soupday ( 3 Years Ago )
Forum Post Thank you so much Victor! By Jfrog ( 3 Years Ago )
Forum Post @Victor.Soupday I just have a little error in the log in Unity... By Jfrog ( 3 Years Ago )
Forum Post [quote][b]Jfrog (6/21/2022)[/b][hr]@Victor.Soupday I just have a... By Victor.Soupday ( 3 Years Ago )
Forum Post [quote][b]Victor.Soupday (6/21/2022)[/b][hr][quote][b]Jfrog... By buonnguqua2k6 ( 3 Years Ago )
Forum Post This tool is amazing! The custom shaders all work really well. I'm... By techniquea2z ( 3 Years Ago )
Forum Post Sorry for the double post, the forums lagged while uploading those... By techniquea2z ( 3 Years Ago )
Forum Post [quote][b]techniquea2z (6/12/2022)[/b][hr]My issue is with the eye... By Victor.Soupday ( 3 Years Ago )
Forum Post I used "Std_Cornea_R" & " Std_Cornea_L". Is that right? I didn't... By techniquea2z ( 3 Years Ago )
Forum Post I meant which eyes did you use from the CC4 content templates? If the... By Victor.Soupday ( 3 Years Ago )
Forum Post I used CC4 Kevin as a base for this character, so it's likely his... By techniquea2z ( 3 Years Ago )
Forum Post Looks like we're good! Not sure how the Occlusion layer should be... By techniquea2z ( 3 Years Ago )
Forum Post The eye occlusion color on Kevin is way too bright for Unity. It... By Victor.Soupday ( 3 Years Ago )
Forum Post Hello ! I first of all wanted to thank you for this add-on and these... By CheoCD ( 3 Years Ago )
Forum Post [quote][b]CheoCD (6/13/2022)[/b][hr]Hello ! I first of all wanted to... By Victor.Soupday ( 3 Years Ago )
Forum Post Running into an issue with skin poking through clothes once the... By chris_466129 ( 3 Years Ago )
Forum Post [quote][b]chris_466129 (6/13/2022)[/b][hr]Running into an issue with... By dgaban ( 3 Years Ago )
Forum Post [quote][b]dgaban (6/17/2022)[/b][hr][quote][b]chris_466129... By chris_466129 ( 3 Years Ago )
Forum Post I was able to import Camilla with no issues, but when I import my own... By rmdhawaii ( 3 Years Ago )
Forum Post [quote][b]rmdhawaii (6/15/2022)[/b][hr]I was able to import Camilla... By Victor.Soupday ( 3 Years Ago )
Forum Post Unity Auto-setup Release 1.3.3 Built-in (Unity 3D):... By Victor.Soupday ( 3 Years Ago )
Forum Post The latest update has resolved my retargetting issues, thanks a lot... By paul.vanderlaan ( 3 Years Ago )
Forum Post I just installed the importer, via PM and tried to import a character... By mike_425218 ( 3 Years Ago )
Forum Post I think I figured out the problem. There as already the maximum number... By mike_425218 ( 3 Years Ago )
Forum Post Hello Victor, it might be out of scope for your plugin but that would... By Necka ( 3 Years Ago )
Forum Post [quote][b]Necka (6/25/2022)[/b][hr]Hello Victor, it might be out of... By Victor.Soupday ( 3 Years Ago )
Forum Post @Victor.Soupday This maybe a bit out of topic but since I have been... By Jfrog ( 3 Years Ago )
Forum Post [quote][b]Jfrog (6/29/2022)[/b][hr]@Victor.Soupday This maybe a bit... By Victor.Soupday ( 3 Years Ago )
Forum Post @Victor.Soupday [quote]There's not really a "Unity Humanoid" that... By Jfrog ( 3 Years Ago )
Forum Post @Victor.Soupday Is there anyway to export blendshapes animations... By dassoubarna ( 3 Years Ago )
Forum Post [quote][b]dassoubarna (6/30/2022)[/b][hr] @Victor.Soupday Is there... By Victor.Soupday ( 3 Years Ago )
Forum Post Some of the things recently added and something still WIP:... By Victor.Soupday ( 3 Years Ago )
Forum Post @Victor.Soupday This is amazing Victor! This tool is getting better... By Jfrog ( 3 Years Ago )
Forum Post Fantastic Victor, you're the best! By tamulur ( 3 Years Ago )
Forum Post Mr Soupday, I’m having an issue with getting my facial animations... By sunriser1116 ( 3 Years Ago )
Forum Post [quote][b]sunriser1116 (7/15/2022)[/b][hr]Mr Soupday,... By Victor.Soupday ( 3 Years Ago )
Forum Post That, my friend, was EXACTLY the problem.You are a genius! I never... By sunriser1116 ( 3 Years Ago )
Forum Post from where i can get 1.3.4 version also can you please share the... By maxkmh ( 3 Years Ago )
Forum Post Unity Auto-setup Release 1.3.4 Built-in (Unity 3D):... By Victor.Soupday ( 3 Years Ago )
Forum Post thanks By maxkmh ( 3 Years Ago )
Forum Post Unity Auto-setup Release 1.3.5 Built-in (Unity 3D):... By Victor.Soupday ( 3 Years Ago )
Forum Post A demonstration video showing adding physics and adjusting the... By Victor.Soupday ( 3 Years Ago )
Forum Post [SOLVED in CC/iC Unity Tools HDRP Version 1.3.6]... By Yules ( 3 Years Ago )
Forum Post Has this been sorted for the URP tool as I have had the same errors... By emelyjohnstone ( 3 Years Ago )
Forum Post [quote][b]emelyjohnstone (8/1/2022)[/b][hr]Has this been sorted for... By Victor.Soupday ( 3 Years Ago )
Forum Post For handling LOD conversions, I need to define the LOD manually in... By kmayfield ( 3 Years Ago )
Forum Post I encountered this error while importing the pluginplease guide... By sitesazy.com ( 3 Years Ago )
Forum Post Hi Victor, i cant use the tool in unity version 2020.3.6f1 with built... By matthias.baudrexl ( 3 Years Ago )
Forum Post So it wasn't just a 2019 problem. The Culprit function:... By Victor.Soupday ( 3 Years Ago )
Forum Post thank you you are best developer unity auto setup Can you design a... By sitesazy.com ( 3 Years Ago )
Forum Post I had a request from my friend Victor.Soupday If it is possible... By sitesazy.com ( 3 Years Ago )
Forum Post [quote][b]sitesazy.com (8/16/2022)[/b][hr] I had a request from my... By Victor.Soupday ( 3 Years Ago )
Forum Post @Victor.Soupday I have an old version of Character Creator (1.3.3)... By Jfrog ( 3 Years Ago )
Forum Post [quote][b]Jfrog (8/23/2022)[/b][hr]@Victor.Soupday I have an old... By Victor.Soupday ( 3 Years Ago )
Forum Post @Victor.Soupday Great! Thank you Victor for the quick reply and... By Jfrog ( 3 Years Ago )
Forum Post Hi Victor, I am having issues where prior to baking I can see... By amelia.baast ( 3 Years Ago )
Forum Post [quote][b]amelia.baast (9/1/2022)[/b][hr]Hi Victor, I am having issues... By Victor.Soupday ( 3 Years Ago )
Forum Post Hi Victor, No we are not using URP, would we be better using the 3D... By amelia.baast ( 3 Years Ago )
Forum Post [quote][b]amelia.baast (9/1/2022)[/b][hr]Hi Victor, No we are not... By Victor.Soupday ( 3 Years Ago )
Forum Post Mr. Soupday, This may not be related to your awesome unity import... By sunriser1116 ( 3 Years Ago )
Forum Post [quote][b]sunriser1116 (9/6/2022)[/b][hr]Mr. Soupday, This may not be... By Victor.Soupday ( 3 Years Ago )
Forum Post [quote] How are you exporting the animation and configuring it in... By sunriser1116 ( 3 Years Ago )
Forum Post @Victor.Soupday Hi I have some queries : 1. Does... By dassoubarna ( 3 Years Ago )
Forum Post [quote][b]dassoubarna (9/11/2022)[/b][hr] @Victor.Soupday Hi I have... By Victor.Soupday ( 3 Years Ago )
Forum Post Hello Soupday, Hope all is well with you and your work. Have a quick... By deidrereaystudios ( 3 Years Ago )
Forum Post [quote][b]deidrereaystudios (9/21/2022)[/b][hr]Hello Soupday, Hope... By Victor.Soupday ( 3 Years Ago )
Forum Post Unity Auto-setup Release 1.3.8 Built-in (Unity 3D):... By Victor.Soupday ( 3 Years Ago )
Forum Post Hey Victor, Just joining the thread to say this is amazing work you... By felgryn ( 3 Years Ago )
Forum Post I totally Agree. Amazing work Victor! Thank you so much for your... By Jfrog ( 3 Years Ago )
Forum Post [quote][b]felgryn (10/2/2022)[/b][hr]Hey Victor, Just joining the... By Victor.Soupday ( 3 Years Ago )
Forum Post Just installed the update 1.3.8b, still getting Unity Warning... By kvergot ( 3 Years Ago )
Forum Post [quote][b]kvergot (10/6/2022)[/b][hr]Just installed the update 1.3.8b,... By Victor.Soupday ( 3 Years Ago )
Forum Post After importing the Characters into Unity, We ran into issues... By EddieChristian ( 3 Years Ago )
Forum Post [quote][b]EddieChristian (10/6/2022)[/b][hr]After importing the... By Victor.Soupday ( 3 Years Ago )
Forum Post Well I have done this 4 times with the standard base and the game base... By EddieChristian ( 3 Years Ago )
Forum Post The Export Packages function doesn't include the custom shaders, for... By Victor.Soupday ( 3 Years Ago )
Forum Post Why is she Green on the Latest Version? I used the Latest shader... By EddieChristian ( 3 Years Ago )
Forum Post It looks Like the Settings folder is not being properly updated on the... By EddieChristian ( 3 Years Ago )
Forum Post [quote][b]EddieChristian (10/11/2022)[/b][hr] Why is she Green on the... By Victor.Soupday ( 3 Years Ago )
Forum Post Hoping for help, I have the previous generation CC3/iClone(7?) and... By michael.pickering ( 3 Years Ago )
Forum Post [quote][b]michael.pickering (11/16/2022)[/b][hr]Hoping for help, I... By Victor.Soupday ( 3 Years Ago )
Forum Post Thanks!! And btw, that Camila rendering looks awesome! By michael.pickering ( 3 Years Ago )
Forum Post Just wanted to pop in say thanks for making an awesome tool! This is a... By bparnell ( 3 Years Ago )
Forum Post Hi @Victor.Soupday, Thank you for putting together the amazing Unity... By zisiang ( 3 Years Ago )
Forum Post [quote][b]zisiang (11/19/2022)[/b][hr] Hi @Victor.Soupday, Thank you... By Victor.Soupday ( 3 Years Ago )
Forum Post Hi @Victor.Soupday, Thanks for getting back to me. When I imported... By zisiang ( 3 Years Ago )
Forum Post [quote][b]zisiang (11/19/2022)[/b][hr] Hi @Victor.Soupday, Thank you... By paul.vanderlaan ( 3 Years Ago )
Forum Post Hi Paul, thank you so much for your reply previously, this is very... By zisiang ( 2 Years Ago )
Forum Post I'm just wondering if there is any way to export from CC4 to an FBX... By clifton_460087 ( 3 Years Ago )
Forum Post [quote][b]clifton_460087 (11/21/2022)[/b][hr]I'm just wondering if... By Victor.Soupday ( 3 Years Ago )
Forum Post Hi Victor, For now, I'm trying to get as far as I can using the CC3+... By michael.pickering ( 3 Years Ago )
Forum Post [quote][b]michael.pickering (11/22/2022)[/b][hr]Hi Victor, For now,... By Victor.Soupday ( 3 Years Ago )
Forum Post So far my results have been amazing with your auto-importer! One... By Motiv8tor ( 2 Years Ago )
Forum Post Is there a workflow stage I am missing with exporting skin texture... By Motiv8tor ( 2 Years Ago )
Forum Post Hi friends I am happy to share the trailer of my dream project with... By dassoubarna ( 2 Years Ago )
Forum Post [quote][b]dassoubarna (1/14/2023)[/b][hr]Hi friends I am happy to... By Victor.Soupday ( 2 Years Ago )
Forum Post Hi @Victor.Soupday First of all I am very happy with your unity asset.... By kell_143901 ( 2 Years Ago )
Forum Post [quote][b]kell_143901 (1/20/2023)[/b][hr]Hi @Victor.Soupday First of... By Victor.Soupday ( 2 Years Ago )
Forum Post Yes I am using URP12 (precisely 12.1.7). The Build Platform is Android... By kell_143901 ( 2 Years Ago )
Forum Post So, here goes. Unity HDRP (2020.3) Wrinkle Map System WIP Test 1... By Victor.Soupday ( 2 Years Ago )
Forum Post [quote][b]Victor.Soupday (1/21/2023)[/b][hr]So, here goes. Unity HDRP... By denon.studios ( 2 Years Ago )
Forum Post That looks amazing! By tamulur ( 2 Years Ago )
Forum Post Hi Victor, First off - wonderful, wonderful tools. I'm so glad that... By felgryn ( 2 Years Ago )
Forum Post [quote][b]felgryn (3/3/2023)[/b][hr]Hi Victor, First off -... By Victor.Soupday ( 2 Years Ago )
Forum Post Hi Victor, Brilliant! This is a super helpful workflow - and... By felgryn ( 2 Years Ago )
Forum Post I'm having some problems importing with the new CC/iC Importer URP... By sal_353974 ( 2 Years Ago )
Forum Post Yes I am having the same issue. Any help would be greatly appreciated.... By Motiv8tor ( 2 Years Ago )
Forum Post Hi Motive, Were you having the same problem I described in my post?... By sal_353974 ( 2 Years Ago )
Forum Post Ok, I've figured it out! I had the clicked export textures as jpg box... By sal_353974 ( 2 Years Ago )
Forum Post Hi everyone and Victor Your plugin is really amazing! Thanks for... By denon.studios ( 2 Years Ago )
Forum Post [quote][b]denon.studios (1/23/2023)[/b][hr]Hi everyone and Victor... By Victor.Soupday ( 2 Years Ago )
Forum Post Hello! Thank you alot for this tool! I'm realy confused about Hair... By chesterspirit47 ( 2 Years Ago )
Forum Post [quote]Defaul after Build Materials it is HDRP/Lit shader, I changed... By Victor.Soupday ( 2 Years Ago )
Forum Post Yep. Thank you. I've changed shader in CC. and after that Unity shows... By chesterspirit47 ( 2 Years Ago )
Forum Post Your missing the Flow Map, the Root Map and the ID Map. In particular... By Victor.Soupday ( 2 Years Ago )
Forum Post I import my character using cc_unity_tools_URP-1.4.4.URP12 to Unity... By Ryan Hayle ( 2 Years Ago )
Forum Post [quote][b]Ryan Hayle (2/22/2023)[/b][hr] I import my character using... By Victor.Soupday ( 2 Years Ago )
Forum Post The issue is the shaders do not work with deferred rendering. e.g. By Ryan Hayle ( 2 Years Ago )
Forum Post [quote][b]Ryan Hayle (2/23/2023)[/b][hr]The issue is the shaders do... By Victor.Soupday ( 2 Years Ago )
Forum Post Ok: URP12 1.4.4.1 With updated shaders for deferred renderer. See... By Victor.Soupday ( 2 Years Ago )
Forum Post Thank you for fixing this so quickly! By Ryan Hayle ( 2 Years Ago )
Forum Post Hi Victor, I have been using your... By GamesAlchemist ( 2 Years Ago )
Forum Post [quote][b]GamesAlchemist (2/15/2023)[/b][hr]Hi Victor,... By Victor.Soupday ( 2 Years Ago )
Forum Post Hi Victor, Ever so sorry to have wasted your... By GamesAlchemist ( 2 Years Ago )
Forum Post Unity Auto-setup Release 1.4.4 Built-in (Unity 3D):... By Victor.Soupday ( 2 Years Ago )
Forum Post Hello, I'm using Unity 2022.2.5f1 and I downloaded and installed the... By chuckterzian ( 2 Years Ago )
Forum Post [quote][b]chuckterzian (2/24/2023)[/b][hr] Hello, I'm using Unity... By Victor.Soupday ( 2 Years Ago )
Forum Post Unity Auto-setup Release 1.4.7 Built-in (Unity 3D):... By Victor.Soupday ( 2 Years Ago )
Forum Post Hi, could you add a refresh button, so we don't have to close and open... By Ryan Hayle ( 2 Years Ago )
Forum Post Hi Victor, thanks for creating this wonderful tool and helping us mere... By kostia.liakhov ( 2 Years Ago )
Forum Post Hard to tell without knowing what lights are in the scene. If it's... By Victor.Soupday ( 2 Years Ago )
Forum Post Thank you for your help, much appreciated. I may not be explaining it... By kostia.liakhov ( 2 Years Ago )
Forum Post [quote][b]kostia.liakhov (3/29/2023)[/b][hr]Thank you for your help,... By Victor.Soupday ( 2 Years Ago )
Forum Post Amazing, this solved it, thank you so much! By kostia.liakhov ( 2 Years Ago )
Forum Post I get the following error when building in Unity 2022.2 URP 14:... By Ryan Hayle ( 2 Years Ago )
Forum Post Hi Ryan, (you'll know me as baroquedub on Messy's server) I started... By jerome.dipietro ( 2 Years Ago )
Forum Post [quote][b]jerome.dipietro (3/29/2023)[/b][hr]Hi Ryan, (you'll know... By Ryan Hayle ( 2 Years Ago )
Forum Post [quote] The error is in the Amplify shader, but yes it could be found... By Victor.Soupday ( 2 Years Ago )
Forum Post did not mean to double post By Jbowdoin ( 2 Years Ago )
Forum Post RE: Unity Auto Setup By Jbowdoin ( 2 Years Ago )
Forum Post how does this plugin detect characters ? it will not find mine also... By Jbowdoin ( 2 Years Ago )
Forum Post sorry if this as been asked, but I don't have a lot of time to look... By Jbowdoin ( 2 Years Ago )
Forum Post [quote][b]Jbowdoin (3/30/2023)[/b][hr]sorry if this as been asked, but... By Victor.Soupday ( 2 Years Ago )
Forum Post "So yes, you can combine a merged mesh version of the character with a... By Jbowdoin ( 2 Years Ago )
Forum Post [quote][b]Jbowdoin (3/30/2023)[/b][hr]"So yes, you can combine a... By Victor.Soupday ( 2 Years Ago )
Forum Post [quote][b]Jbowdoin (3/29/2023)[/b][hr] [/quote] Where has the... By Victor.Soupday ( 2 Years Ago )
Forum Post @ Victor.Soupday Would it be possible to add a batch feature to the... By jerome.dipietro ( 2 Years Ago )
Forum Post Unity Auto-setup Release 1.4.8 Built-in (Unity 3D):... By Victor.Soupday ( 2 Years Ago )
Forum Post Hello Victor, Thank you for your work! I am trying to setup wrinkles... By pragmavr ( 2 Years Ago )
Forum Post [quote][b]expi (4/28/2023)[/b][hr]Hello Victor, Thank you for your... By Victor.Soupday ( 2 Years Ago )
Forum Post Hello I did everything like in the this youtube tutorial, but for some... By Duude ( 2 Years Ago )
Forum Post [quote][b]Duude (5/15/2023)[/b][hr]Hello I did everything like in the... By Victor.Soupday ( 2 Years Ago )
Forum Post I am making VR game so I use VR template in unity Well I tested HDRP... By Duude ( 2 Years Ago )
Forum Post I now tested the CC4 kevin default and it works correctly when... By Duude ( 2 Years Ago )
Forum Post Solution found https://www.youtube.com/watch?v=ED9ZlcILJfY By Duude ( 2 Years Ago )
Forum Post Hello I Just Purchase Character Creator 4. I export my character as... By buckbuck ( 2 Years Ago )
Forum Post [quote][b]buckbuck (5/26/2023)[/b][hr]Hello I Just Purchase Character... By Victor.Soupday ( 2 Years Ago )
Forum Post Hi Victor, Thanks for your great work, it is great that you... By gai.s ( 2 Years Ago )
Forum Post I am using the Invector template. How i can adjust the shoulder and... By maxkmh ( 2 Years Ago )
Forum Post Dear developer, We are currently experiencing a weird shader/material... By abhayj ( 2 Years Ago )
Forum Post One possibility is that the custom Shaders aren't installed in your... By Victor.Soupday ( 2 Years Ago )
Forum Post Dear developer, we are using iClone characters in a URP game in VR.... By marius.rubo_388786 ( 2 Years Ago )
Forum Post I have a question about blendshapes within exported animations,... By dan.goyette ( 2 Years Ago )
Forum Post Hi, I update a project from unity 2022.3 to 2023.1.2, with the new URP... By masai ( 2 Years Ago )
Forum Post [quote][b]masai (7/4/2023)[/b][hr]Hi, I update a project from unity... By Victor.Soupday ( 2 Years Ago )
Forum Post Hi Victor, I continue to have the same error: Shader error in... By masai ( 2 Years Ago )
Forum Post [quote][b]masai (7/22/2023)[/b][hr]Hi Victor, I continue to have the... By Victor.Soupday ( 2 Years Ago )
Forum Post Hi All, Just loving Soupday's Unity Tools. Just upgraded our... By felgryn ( 2 Years Ago )
Forum Post Dear developer, We have currently facing an issue where the Decal in... By abhayj ( 2 Years Ago )
Forum Post I started a clean new project in Unity 2022.3.5f1 LTS, imported the... By j_a_booth ( 2 Years Ago )
Forum Post [quote][b]j_a_booth (7/20/2023)[/b][hr]I started a clean new project... By Victor.Soupday ( 2 Years Ago )
Forum Post [quote][b]Victor.Soupday (7/26/2023)[/b][hr][quote][b]j_a_booth... By j_a_booth ( 2 Years Ago )
Forum Post Hello, When i start a new scene or save content, sometimes this... By felgryn ( 2 Years Ago )
Forum Post [quote][b]felgryn (7/25/2023)[/b][hr]Hello, When i start a new scene... By Victor.Soupday ( 2 Years Ago )
Forum Post Hi Victor, Many thanks for the quick reply! I think the importer... By felgryn ( 2 Years Ago )
Forum Post Hey Unity Auto SetUp Fans! Just wanted to share a clip that shows... By felgryn ( 2 Years Ago )
Forum Post I have a support ticket and Rampa wants me to ask about it in here.... By jmi3 ( 2 Years Ago )
Forum Post Unity Auto-setup Release 1.5.1 Built-in (Unity 3D):... By Victor.Soupday ( 2 Years Ago )
Forum Post One small feature request: It would be nice if... By dan.goyette ( 2 Years Ago )
Forum Post [quote][b]dan.goyette (7/31/2023)[/b][hr]One small feature request: It... By Victor.Soupday ( 2 Years Ago )
Forum Post [quote][b]Victor.Soupday (8/2/2023)[/b] There were a few other bugs in... By dan.goyette ( 2 Years Ago )
Forum Post [quote][b]dan.goyette (8/3/2023)[/b][hr][quote][b]Victor.Soupday... By Victor.Soupday ( 2 Years Ago )
Forum Post [quote][b]Victor.Soupday (8/3/2023)[/b] and/or steps to reproduce this... By dan.goyette ( 2 Years Ago )
Forum Post [quote] For the Include Motion -> Custom section, I've just... By Victor.Soupday ( 2 Years Ago )
Forum Post Ah, interesting. I'll report it as a bug, in that case. I did try the... By dan.goyette ( 2 Years Ago )
Forum Post A couple of things I noticed when updating from 1.4.9 to 1.5.1:... By dan.goyette ( 2 Years Ago )
Forum Post Unity Auto-setup Release 1.5.2 Built-in (Unity 3D):... By Victor.Soupday ( 2 Years Ago )
Forum Post On the topic of the importer not breaking references to things,... By dan.goyette ( 2 Years Ago )
Forum Post A small issues I noticed on some hair meshes. It looks like some... By dan.goyette ( 2 Years Ago )
Forum Post I have a question about Normals on models. I see that the importer... By dan.goyette ( 2 Years Ago )
Forum Post [quote][b]dan.goyette (8/15/2023)[/b][hr]I have a question about... By Victor.Soupday ( 2 Years Ago )
Forum Post [quote][b]Victor.Soupday (8/17/2023)[/b] The fix, supposedly, is to... By dan.goyette ( 2 Years Ago )
Forum Post [quote][b]dan.goyette (8/18/2023)[/b][hr][quote][b]Victor.Soupday... By Victor.Soupday ( 2 Years Ago )
Forum Post I have a problem with wrinkles in Unity URP. Everything works nicely... By marius.rubo ( 2 Years Ago )
Forum Post [quote][b]marius.rubo (8/25/2023)[/b][hr]I have a problem with... By Victor.Soupday ( 2 Years Ago )
Forum Post Brilliant, that did it! By marius.rubo ( 2 Years Ago )
Forum Post Hello, - Is it possible to export a character "instaLOD" version... By babyfoothero ( 2 Years Ago )
Forum Post [quote][b]babyfoothero (8/28/2023)[/b][hr]Hello, - Is it possible to... By Victor.Soupday ( 2 Years Ago )
Forum Post Hi, Is it worth getting the skin-gen tool in CC4 and does it work with... By sirsquish ( 2 Years Ago )
Forum Post [quote][b]sirsquish (9/26/2023)[/b][hr]Hi, Is it worth getting the... By Victor.Soupday ( 2 Years Ago )
Forum Post "Daz details are tricky. You may need up the resolution of the baked... By sirsquish ( 2 Years Ago )
Forum Post Here's a situation I'm finding myself in, but I'm not sure if there's... By dan.goyette ( 2 Years Ago )
Forum Post Hi, I am having issues with connecting the prefab to the avatar to add... By cristine ( 2 Years Ago )
Forum Post [quote][b]cristine (9/27/2023)[/b][hr]Hi, I am having issues with... By Victor.Soupday ( 2 Years Ago )
Forum Post Sorry if this has been asked before, but does the Unity exporter... By sickybricky ( 2 Years Ago )
Forum Post [quote][b]sickybricky (9/28/2023)[/b][hr]Sorry if this has been asked... By Victor.Soupday ( 2 Years Ago )
Forum Post hello, i was just testing the wrinkle maps, first in urp then in hdrp,... By objectnull ( 2 Years Ago )
Forum Post [quote][b]objectnull (9/29/2023)[/b][hr]hello, i was just testing the... By Victor.Soupday ( 2 Years Ago )
Forum Post [quote][b]Victor.Soupday (9/29/2023)[/b][hr][quote][b]objectnull... By objectnull ( 2 Years Ago )
Forum Post [quote] Is that in Play mode? It's this problem:... By objectnull ( 2 Years Ago )
Forum Post [quote][b]objectnull (9/29/2023)[/b][hr][quote] does it also need to... By Victor.Soupday ( 2 Years Ago )
Forum Post alright, that does make sense, i just copy pasted the files to the... By objectnull ( 2 Years Ago )
Forum Post alright, that did the trick. add it to the package manager by adding... By objectnull ( 2 Years Ago )
Forum Post Something seems really messed up with the _extracted meshes that are... By dan.goyette ( 2 Years Ago )
Forum Post [quote][b]dan.goyette (10/6/2023)[/b][hrI created a new CC4 project,... By Victor.Soupday ( 2 Years Ago )
Forum Post Hello! I made a post that I recently updated but not sure it will be... By josephgovi.n ( 2 Years Ago )
Forum Post [quote][b]josephgovi.n (10/6/2023)[/b][hr]Hello! I made a post that I... By Victor.Soupday ( 2 Years Ago )
Forum Post using the URP 10 version oddly enough worked for me. Thanks for the... By luke_545764 ( 2 Years Ago )
Forum Post Hi I am using Unity 2022.3.10f1 and URP and your tools version 1.5.2... By glenn_235118 ( Last Year )
Forum Post [quote][b]glenn_235118 (1/12/2024)[/b][hr]Hi I am using Unity... By Victor.Soupday ( Last Year )
Forum Post Hi Victor, I have and the hair and skin still turn up pink. By glenn_235118 ( Last Year )
Forum Post [quote][b]glenn_235118 (1/22/2024)[/b][hr]Hi Victor, I have and the... By Victor.Soupday ( Last Year )
Forum Post Hi Victor, thank you for the additional information. We will... By glenn_235118 ( Last Year )
Forum Post i need to know what changes you did to make cc4 character on webgl... By adityaasp.net ( Last Year )
Forum Post I would like to briefly describe the problem I encountered: hair... By 1711873140 ( 2 Years Ago )
Forum Post If your project also has these mistakes, you can see my question... By 1711873140 ( 2 Years Ago )
Forum Post Hi there, I was trying to import CC4 models into my URP project... By eduu.porto ( 2 Years Ago )
Forum Post [quote][b]eduu.porto (10/9/2023)[/b][hr] Hi there, I was trying to... By Victor.Soupday ( 2 Years Ago )
Forum Post I don't know if you have noticed the grid on the character's skin,... By 1711873140 ( 2 Years Ago )
Forum Post [quote][b]1711873140 (10/15/2023)[/b][hr] I don't know if you have... By Victor.Soupday ( 2 Years Ago )
Forum Post Hi there, I just wanted to make a couple of nice-to-have feature... By dan.goyette ( 2 Years Ago )
Forum Post I ran into a minor issue with the LOD Combiner tool. It looks like the... By dan.goyette ( 2 Years Ago )
Forum Post One other very minor thing: The Icon colors of many of the icons... By dan.goyette ( 2 Years Ago )
Forum Post One kind of minor thing with the LOD Combiner: It doesn't really work... By dan.goyette ( 2 Years Ago )
Forum Post Is the 3D (Built-In Render Pipeline) able to use the DEFERRED... By dprassel ( 2 Years Ago )
Forum Post I have exported everything correctly, and set everything right just... By microblastgames ( 2 Years Ago )
Forum Post [quote][b]microblastgames (12/6/2023)[/b][hr] I have exported... By Victor.Soupday ( 2 Years Ago )
Forum Post As I said, I have downloaded the latest version. By microblastgames ( 2 Years Ago )
Forum Post Check the FBX Importer settings for the character, that is has Legacy... By Victor.Soupday ( 2 Years Ago )
Forum Post Thanks Victor! The problem was the Wrinkle Manager. I disabled it in... By microblastgames ( 2 Years Ago )
Forum Post I created a female character in Character Creator and I need to... By 1711873140 ( 2 Years Ago )
Forum Post [quote][b]1711873140 (12/18/2023)[/b][hr] I created a female character... By Victor.Soupday ( 2 Years Ago )
Forum Post After changing the color of the character's hair from diffuse color,... By ozanyilmazdev ( 2 Years Ago )
Forum Post [quote][b]ozanyilmazdev (12/18/2023)[/b][hr] After changing the color... By sirsquish ( 2 Years Ago )
Forum Post The materials of the remeshed lods come combined, not separately, so I... By ozanyilmazdev ( 2 Years Ago )
Forum Post [quote][b]ozanyilmazdev (12/18/2023)[/b][hr] After changing the color... By Victor.Soupday ( 2 Years Ago )
Forum Post Greetings and Happy New Year!! I've recently updated to the latest... By michael.pickering ( 2 Years Ago )
Forum Post Hi! New user here. This is the list of supported Unity features for... By bryanhpchiang ( Last Year )
Forum Post Hello, everyone! I'm currently working on integrating an iClone... By jphartley21 ( Last Year )
Forum Post [quote][b]jphartley21 (2/6/2024)[/b][hr] Hello, everyone! I'm... By Victor.Soupday ( Last Year )
Forum Post Thanks for the quick response. I actually noticed that mistake since... By jphartley21 ( Last Year )
Forum Post Everything seems to be working now. Thank you! By jphartley21 ( Last Year )
Forum Post Hey Soupday, Thanks for all the work on this tool, it's been so easy... By bobcarlan ( Last Year )
Forum Post I'm still on 1.5.2, but I don't see a fix for this in 1.6.1, so I'm... By dan.goyette ( Last Year )
Forum Post Hi, I'm trying to import my character from CC4 to Unity and having... By bini_435707 ( Last Year )
Forum Post [quote][b]bini_435707 (3/11/2024)[/b][hr]Hi, I'm trying to import my... By Victor.Soupday ( Last Year )
Forum Post 안녕하세요 ! https://soupday.github.io/cc_unity_tools/usage.html... By thsguswl0722_619279 ( Last Year )
Forum Post Hi, Im a new user and I'm pretty new to unity as well. I've been... By hassan953nazeer ( Last Year )
Forum Post Hello, I recently tried to put my character in unity but I've been... By amomuitojessus ( Last Year )
Forum Post [quote][b]amomuitojessus (4/10/2024)[/b][hr] Hello, I recently tried... By Victor.Soupday ( Last Year )
Forum Post when I export my character using CC4 FBX to Unity, and I use the... By vincenthung6855 ( Last Year )
Forum Post [quote][b]vincenthung6855 (4/19/2024)[/b][hr] when I export my... By Victor.Soupday ( Last Year )
Forum Post Hi I am trying to use CC4 character inside unity 2023 which supports... By adityaasp.net ( Last Year )
Forum Post Hi, Unity 2022.3.16f1 - 3D core project type Auto-setup tool for... By huntc938 ( Last Year )
Forum Post Hi Victor SoupdayI hope you're doing well. I’ve been following your... By mumiasms ( Last Year )
Forum Post Hello! Thanks to everyone that has worked on this tool -- it is really... By allentg ( Last Year )
Forum Post I know this is likely the wrong place to post this but I have a VR... By jcjohnny5 ( Last Year )
Forum Post Hi Victor, Can you help me please? I'm using URP renderer and have a... By mark.jsday ( Last Year )
Forum Post Hi Victor Are you going to support the wrinkles in your Shader Graph... By mark.jsday ( Last Year )
Forum Post [quote][b]mark.jsday (6/24/2024)[/b][hr]Hi Victor, Can you help me... By Victor.Soupday ( Last Year )
Forum Post Yes ive tried that but its not working. When i check the debug its... By mark.jsday ( Last Year )
Forum Post To fix this issue i had to include (to the template) the pragma to the... By mark.jsday ( Last Year )
Forum Post Which version of Unity and ASE are you using? I'm fairly sure it... By Victor.Soupday ( Last Year )
Forum Post I'm using Soupday's Version 1.4.7 HDRP shaders... I've seem to run... By chris_466129 ( Last Year )
Forum Post Just wondering if there are any plans to upgrade this for URP 17? It'd... By mat365 ( Last Year )
Forum Post Hi, After much investigation I realized that we have an issue with... By bmslab ( Last Year )
Forum Post Is there any chance the wrinkle maps could be supported for shader... By mark.jsday ( Last Year )
Forum Post [quote][b]mat365 (7/6/2024)[/b][hr]Just wondering if there are any... By Victor.Soupday ( Last Year )
Forum Post Another Reallusion CC4 character import questions (S hader pink... By aidesigner ( Last Year )
Forum Post [quote][b]aidesigner (7/28/2024)[/b][hr]Another Reallusion CC4... By Victor.Soupday ( Last Year )
