1711873140
1711873140
Visits: 52
 I don't know if you have noticed the grid on the character's skin, with diagonal textures on the face. I accidentally eliminated it before, but I don't know how to do it
luke_545764
luke_545764
Visits: 46
using the URP 10 version oddly enough worked for me. Thanks for the tip. Amazingly all the shaders seem to work in WebGL platform too. :D
Victor.Soupday
Victor.Soupday
Visits: 9.0K
josephgovi.n (10/6/2023)
Hello! I made a post that I recently updated but not sure it will be coming back. I will recreate it here in case it disappeared entirely. I made a support ticket about this issue also, but they directed me here instead. I tried using Unity Auto Setup for URP but I get broken results when I try generating High Quality Materials for imported CC4 Characters:  I get what I think are expected results for clothing items, but for all skin related materials/shaders I get a Hidden/Internal shader error. Am I doing something wrong for URP usage? Here are some details about software: Unity: 2022.3.10f1 URP: 14.0.8 CC4: 3.31.2001.1 Unity Auto Setup Version 1.5.2 URP When I export from cc4 my settings are as follows: Any help is appreciated, thank you Are you using a deferred renderer and the URP14 version of the tool? I think there might be a problem with some of the shaders using the deferred renderer in the URP14 tool. Does it work correctly with the URP12 version of the tool? The URP12 tool should still work, even in Unity URP14.
Victor.Soupday
Victor.Soupday
Visits: 9.0K
eduu.porto (10/9/2023)
Hi there, I was trying to import CC4 models into my URP project using Auto Setup 1.5.2 for URP15 into my project in Unity 2023.1.16f1 and I am getting pink materials and shaders with compiler errors. Pink shaders usually means you have the wrong version for the render pipeline, but I'd need to see the errors to be sure.
Victor.Soupday
Victor.Soupday
Visits: 9.0K
I'm not sure what's not exportable about it but that particular hair does work in Unity.
Victor.Soupday
Victor.Soupday
Visits: 9.0K
cristine (9/27/2023)
Hi, I am having issues with connecting the prefab to the avatar to add animations (see screenshot). The system DOES see the avatar, but when I click on it, nothing happens and source goes back to "None". Please advise.  All of a sudden lots of new posts from the past two weeks have just appeared... is there something wrong with the forum? Anyway: You can't copy an avatar from itself. You have to set it generate the avatar from that model ( Create from this model). Because when you set it to copy, it won't generate the avatar for that model. So there's nothing to copy, which is why it reverts to None.
eduu.porto
eduu.porto
Visits: 23
1711873140
1711873140
Visits: 52
If your project also has these mistakes, you can see my question above, because it is a very stupid question, don't waste your time like I did
1711873140
1711873140
Visits: 52
I would like to briefly describe the problem I encountered: hair and eyeballs these special shader transparent display, this is a mistake:Cannot create a custom UI for shader 'Reallusion/Amplify/RL_HairShader_1st_Pass_Variants_URP'. The coloring appliance has the following contents: "CustomEditor = ASMaterialInspector". Does the specified custom editor include its namespace? Is this class derived from ShaderGUI or MaterialEditor? Unity Engine. GUIUtility: ProcessEvent(int, intptr, bool &) I have found the problem because I used the wrong template.....
josephgovi.n
josephgovi.n
Visits: 86
