Imported Character from CC gets different facial expression in iClone! How can I keep expression?
Posted By cgi_468384 4 Years Ago
Imported Character from CC gets different facial expression in iClone!...
cgi_468384
cgi_468384
Veteran Member (736 reputation)Veteran Member (736 reputation)Veteran Member (736 reputation)Veteran Member (736 reputation)Veteran Member (736 reputation)Veteran Member (736 reputation)Veteran Member (736 reputation)Veteran Member (736 reputation)Veteran Member (736 reputation)
Posts: 42, Visits: 146
Hello,
I have a CCplus character with slightly opened mouth in CC and when I send it to iClone, it gets a different facial default expression with more closed mouth.
(especially in this case the default expression must exactly match the original facial expression).
I have already set in CC a "default Pose", but I don't see "set as default facial expression" anywhere in CC.
How can I solve this?
Thanks
Posts: 23.1K, Visits: 36.6K
Hi...
please try saving a copy of your CC3 project to say your Desktop or Documents folder and then change the project file extension from .ccProject to .iProject.
Now open this project in iClone and check to see if the facial expression is correct.
cgi_468384
cgi_468384
Thanks, sounds interesting, I will try this.
I found meanwhile the method, to save the pose as "MotionPlus" in CC as a template,
and then open the folder in the explorer and drag&drop this ".iMotionPlus"-file directly into iClone on the imported FBX.
It seemed to work quite good.
