ckalan1
ckalan1
Visits: 10.7K
Has anyone else had this issue? When I moved my custom content (specifically iAvatars) from the custom pack to a pack I made called Characters the files got mislabeled. It appears as though the files got named the wrong names but the data did not get overwritten. This happened when I selected multiple Avatars from the custom pack and moved them into the new pack at the same time. If you look at the attached image you will see how the male figures and the female figures are now mislabeled. When I load a character into the scene the character loads like the thumbnail in the pack even though the label is incorrect. But in the Scene panel, the avatar's name seems to be correct. The Character's correct name appears in the Name/Avatar list. After I loaded the Avatar and then tried to Apply it back over the Thumbnail from where it came from, the incorrect name stayed the same. When I use the Save button the Save Options panel appears so I can assign a File Name. But then I get a message asking if I want to add (1) because a file already exists with the name.
