UE5 & Reallusion - Tips & Tricks
Posted By StyleMarshal 4 Years Ago
378
379
380
381
382
473
marcusdriessen
marcusdriessen
Posted Last Year
New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)
Posts: 9, Visits: 112
So the solution is one of the books. I watched the tutorial from Reallusion on Youtube again:)
- When the wrapping is done with Headshot V2, send your mesh to Zbrush or Blender and subdivide it around 4 times. 1 million polys is enough.
- Export it as an .obj and name it mymesh_HD for example.
- When exporting with the 'Export Head' function in CC, select the exported subdivided HD mesh as you high poly mesh for baking.
Problem solved:)
marcusdriessen
marcusdriessen
Posted Last Year
SORRY for the double post:( and not sure why the post I replied to isn't attached to....
Problem solved:)
hoodtronik
hoodtronik
Posted Last Year
Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)
Posts: 46, Visits: 297
Thanks for the quick reply , Bassline! and the 5.3 plug-in.  And you're right. Something glitchy is happening with my iClone 8 installation when I export fbx animations.  All of them are exporting with just a t-pose. I hope the recent update didn't break anything. I'm hoping its just that particular project being corrupted. Which really sucks, but I can atleast find a workaround for it. So, with the the setup you and Toby figured out, I should be able to export the animation directly to the Metahuman character from the CC4 character?
hoodtronik
hoodtronik
Posted Last Year
Okay after a few more tests, it seems the Unreal FBX export is broken in my iClone 8 installation. I have to use Maya FBX export or one of the other ones.  I think it may have been the recent update. I uninstalled and reinstalled iClone 8 and it is still there.
StyleMarshal
StyleMarshal
Posted Last Year
Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)
Posts: 5.8K, Visits: 14.3K
ilyas.nashid (1/19/2024)
strange , works fine here ,  also be sure to add the fps you used in IClone (default is 60) in the UE5 fbx import advanced settings :
When importing deactivate import mesh and select the the CC4 skeleton you use to drive the Meta Human:
75% of original size (was 668x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/17495545-40a7-4243-8080-0c7c.jpg
P.S. or use Take Recorder with Timecode Sync to record the animation ...
hoodtronik
hoodtronik
Posted Last Year
Thanks! That was actually exactly my issue. I had the iClone FPS set to 30fps instead of 60. Lesson Learned! Thanks as always Bass!
marcusdriessen
marcusdriessen
Posted Last Year
How bi-directional is the connection between iCLone and Unreal?
I was playing with the 'Look at' function in iClone hooked up to a custom MetaHuman in Unreal. All works great. But switching between UE en IC is quite a hassle.
So I was wondering....would it be possible to transfer the look at object to UE and control it from there, while sending data back to IC?
If that not's possible I might try this route below (without IC), but it's a tedious process;)
https://www.youtube.com/watch?v=NZmQPSKf7YY
toystorylab
toystorylab
Posted Last Year
Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)
Posts: 4.6K, Visits: 29.9K
I finally found time to play around with Rush Hour:
This is all done in Unreal, but the characters were still animated with iClone...
Toystorylab on Vimeo : 75% of original size (was 668x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/ce44ea78-6984-47d8-9bf4-b783.png    Crassitudes (my "Alter Ego") on Youtube: 75% of original size (was 668x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/fcc4df30-b3a8-40a5-a427-0735.png
StyleMarshal
StyleMarshal
Posted Last Year
toystorylab (1/20/2024)
Awesome Toy , it looks really cool 👍
StyleMarshal
StyleMarshal
Posted Last Year
WoW , trailer mostly made by one person and he is a newbie in UE5 :
378
379
380
381
382
473
