Bassline303
Bassline303
Posts: 5.8K,
Visits: 14.2K
rosuckmedia (11/2/2022)
Hello, I have a question, How can I the CSV import UE 5.1 into UE5.0.3 imigrate. Greetings Robert The easiest way is to bake down the CSV data into an animation sequence and then migrate or copy it over to your UE5 project. But be sure your Characters have the ExPlus facial profile.
rosuckmedia
rosuckmedia
Posts: 3.2K,
Visits: 4.8K
Hi bassline, How do I migrate them? The baked animation Copy, and paste into 5.03 ?? Greetings Robert
2 Years Ago by
rosuckmedia
Bassline303
Bassline303
Posts: 5.8K,
Visits: 14.2K
Hi bassline, How do I migrate them? The baked animation Copy, and paste into 5.03 ?? Greetings Robert Make a folder (CSV Animations for example) move or copy all the animations into that folder. Right click on the folder and select "migrate". When it is asking where to migrate choose your UE5 Project/Content. When it is migrated you have to retarget to a CC4 skeleton or share a CC4 skeleton. You also can migrate your CC4 character (used in UE5.1) to UE5. (and vice versa)
2 Years Ago by
Bassline303
rosuckmedia
rosuckmedia
Posts: 3.2K,
Visits: 4.8K
Ah Okay, Thanks Bassline, I only use MH. Greetings Roberto😁😁😁
Bassline303
Bassline303
Posts: 5.8K,
Visits: 14.2K
Ah Okay, Thanks Bassline, I only use MH. Greetings Roberto😁😁😁 Same thing , but more easy because you only have to choose the Meta Human Skeleton and there is only one 😁
Mr Dee
Mr Dee
Last Active: 8 days ago
Visits: 755
Hey guys, I posted a question in UE4/5 with no response. So maybe here is a better place Take Recorder not capturing head rotation with iClone link setupI'm having a little trouble recording motion and facial data from iClone to Unreal using the take recorder. My setup is pretty standard. I'm using a CC4 character to drive the facial data and a Humanoid character matching the bodytype to drive the skeletal mesh in UE. This al works as it should however..... I created an animation on the CC4 character with facepuppet. This animation also has head rotation data. This data is transfered to UE and also shown when TakeRecorder is running. But when replaying or applying the recorded data to the MH only the facial animation is playing without the head rotation. I've tried disconnecting the humanoid rig while recording, but with no luck. Any idea's for a workaround on this? Cheers, Marcus
Bassline303
Bassline303
Posts: 5.8K,
Visits: 14.2K
@Mr Dee You have to do all bone animations in IClone with the Dummy and all facials with the CC4. When you add head shaking (for example) to the CC4 it will be overwritten by the body BP , so you have to add the head shaking to the Dummy in IClone. You can do your head animation with the CC4 but you will need to copy it over to the dummy too , to record it with Take Recorder.
2 Years Ago by
Bassline303
Bassline303
Bassline303
Posts: 5.8K,
Visits: 14.2K
Bassline303 (11/2/2022)
Ah Okay, Thanks Bassline, I only use MH. Greetings Roberto😁😁😁 Same thing , but more easy because you only have to choose the Meta Human Skeleton and there is only one 😁 BTW , migrating CSV animations to UE5.03 doesn't work anymore with UE5.1p2 , you will need to work in UE5.1. A workaround is to export the animation data as fbx out of UE5.1 and import it into UE5.03 for the Face_Archetype_Skeleton (MH)
2 Years Ago by
Bassline303
Mr Dee
Mr Dee
Visits: 755
@bassline303 I was afraid this was the case;( Such a pity cause the head animation created by RL FacePuppet matches the eye motion and all other movements so well. Creating it by hand with the dummy doesn't look that 'synced' and great. Maybe there's a way to copy those specific bone tracks from the CC character to the Dummy in RL and than record this with the takerecorder. Also would be great if RL would let us export CSV files directly from iCLone Cheers, Marcus
Bassline303
Bassline303
Posts: 5.8K,
Visits: 14.2K
Mr Dee (11/2/2022)
@bassline303 I was afraid this was the case;( Such a pity cause the head animation created by RL FacePuppet matches the eye motion and all other movements so well. Creating it by hand with the dummy doesn't look that 'synced' and great. Maybe there's a way to copy those specific bone tracks from the CC character to the Dummy in RL and than record this with the takerecorder. Also would be great if RL would let us export CSV files directly from iCLone Cheers, Marcus You can save your CC4 animation as "motion" and load it to the Dummy (bones) So do all body animations in IClone with the CC Character and save it as "motion".
2 Years Ago by
Bassline303
