After Effects Exporter Rendering Problem
Posted By jeremyfisher 4 Years Ago
jeremyfisher
jeremyfisher
New Member (72 reputation)New Member (72 reputation)New Member (72 reputation)New Member (72 reputation)New Member (72 reputation)New Member (72 reputation)New Member (72 reputation)New Member (72 reputation)New Member (72 reputation)
Posts: 3, Visits: 110
I contacted tech support and it's a problem with custom props, but the template props work fine with motions. They will hopefully fix this in the next update. So for now it'll have to be an AE workaround until then.
OldschoolAnimator
OldschoolAnimator
Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)Veteran Member (575 reputation)
Posts: 47, Visits: 818
I've had issues from the beginning with the exporter as well, though not with the sprites like you're encountering.  I had to use a workaround to get my scenes into AE.
jeremyfisher
jeremyfisher
Hey everyone!
I've been having a problem with the After Effects Exporter where it doesn't properly render out props that have motion, especially with a different curve. You can see from the video that it's skipping the frames that would have the curve applied to it.
Does anyone know why this happens or know a fix for it? I was using the basic Enlarge Elastic Motion. I've tried different settings in the AE Exporter and it all comes out the same, very choppy. Rendering normally, however, has no problems so I know it's strictly the AE Exporter not rendering out all the frames.
