Amper Sand
Amper Sand
Visits: 5.2K
I want to make an object shaking (or trembling) quite rapidly. I know it can be achieved with some effort (but not very good looking) by manually keyframing its transform or/and motion. But as far as I remember, I think I've read somewhere here some year ago about some plugin able to convert a waveform from an mp3 to such motion, but I'm not sure :D Or maybe somebody has an idea about how to do this. Thanks!
______________________________________________________________________________ Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend In progress: Black Mamba AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
gordryd
gordryd
Last Active: 10 days ago
Visits: 8.0K
Hi Ampertox, I created a plug-in that can shake either camera -OR- props. This could probably do what you are looking for: https://marketplace.reallusion.com/shakycam-plusYou can control the axis, amount of shaking, and frame range.
thebiz.movies
thebiz.movies
Posts: 2.1K,
Visits: 42.3K
Might be worth considering the motion puppet and achieving the effect via the mouse.
Amper Sand
Amper Sand
Visits: 5.2K
@gordryd Thank you, I will try it, it didn't have it :) @thebiz.movies Thank you! The problem is my english is not so good: what I want to achieve is closer to vibration rather than shaking - if you imagine, for instance, an object on the edge of the table when earthquake begins - the motion would involve very small variations around a central point, I don't think the puppet with mouse can achieve this, better manual keyframing.
Posts: 5.3K,
Visits: 16.8K
Regarding audio waveform, there was a script by RL https://forum.reallusion.com/FindPost416817.aspxBut it is messy to play with.
Amper Sand
Amper Sand
Visits: 5.2K
https://www.youtube.com/watch?v=pX84nW6y8Ko :D
Posts: 5.3K,
Visits: 16.8K
lol yeah Took me a week to disassemble that script to understand how the damn thing is working and then filter bass and treble and then shake/move/tile the UVs on some materials based on that :Whistling: If you brave enough, you can sure create an earthquake base on some generated audio files. :):cool:
esemgee
esemgee
Visits: 469
Are you doing everything in iClone? I would possibly try and do what you want in post - After Effects and use wiggle - I have used this to get camera shake and you have total control. Or in iClone layer the object four or five times, reducing opacity on the underlying ones and shift each one slightly from side to side.
Amper Sand
Amper Sand
Visits: 5.2K
esemgee (6/19/2021) Are you doing everything in iClone? I would possibly try and do what you want in post - After Effects and use wiggle - I have used this to get camera shake and you have total control. Or in iClone layer the object four or five times, reducing opacity on the underlying ones and shift each one slightly from side to side.
I wasn't interested to shake the camera (which yes, can be easily done in post-editing) I was interested to shake an object - in my case, character's hand. I highly doubt this feat can be achived (easier) in video post-editing.
