Free Light Cube Prop with available Python Script Plug-in To Control It (Costs $4 Dollars)
Posted By Data Juggler 4 Years Ago
Free Light Cube Prop with available Python Script Plug-in To Control...
Data Juggler
Data Juggler
Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)Distinguished Member (13.9K reputation)
Posts: 1.8K, Visits: 5.6K
Free Light Cube
https://marketplace.reallusion.com/light-cube
A Light Pipe consists of four sets of point lights, all wrapped in a pipe.
92% of original size (was 547x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/885425f0-66dd-4142-ba19-ce4e.png
Each of the sets of four light pipes , is then attached to a box, and is called a Light Cube (actually it is a rectangle).
92% of original size (was 547x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/8f799188-ff70-4984-81ab-f8ae.png
The advantages to using a Light Cube are below.
1. A Light Cube can be controlled by the Light Pipes Controller.py Python script (add on product that costs 400 points or $4 dollars).
2. The child light pipes are attached to the box Light Cube, but the scale is not inherited so you can easily size your lights into place.
3. Light cubes provide soft lighting, and you can set each light to the range and strength you want, all 16 (or buy the Python Script, its worth it).
Think of the Light Cube as the car body, and if you want it to do anything other than you pushing it yourself, then the Light Pipes Controller is the engine.
Light Pipes Controller.py - 400 Points or $4.00
https://marketplace.reallusion.com/light-pipes-controller
This python script is made specifically for the Light Cubes, although it would be easy for you to modify for your own lights if you wish.
If the Light Cube is worth free, then here are the reasons this plug-in is worth $4.
1. If you show the Light Cube or any of the Light Pipes, IClone will show the range lines. Run the Light Pipes Controller.py Python script and click the Hide All Lights button, and this will hide the lights, but leave the light pipes visible.
2. You can set the range and color values for all the red, green, blue and yellow light pipes at a given frame number on the timeline, and click the Apply Lights button. This will apply the lighting to that frame, and as you add lights to other frames your lights will change. It is just an easy way to animate the light colors and even total darkness by setting all lights to off (and removing all other lights, and setting your project background to an all black image).
Here is the first video I have made so far using the lounge project, since everyone has it.
More videos coming soon.
Creator of the free website:
PixelDatabase.Net
A Free Online Text Based Image Editor
92% of original size (was 547x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/6e6663e2-0ecf-447a-ab3d-d49d.png
wsessoms
wsessoms
Posts: 117, Visits: 508
Nice Python Script!
Dell Precision T5500; Windows 10 Pro; Dual Xeon 5687 3.60GHz Processors; 72GB Ram; NVIDIA GeForce RTX 3080; Samsung 1TB SSD; Seagate 2TB 7200RPM HDD; Wacom Intuos Tablet; ASUS Dual Monitors
Data Juggler
Data Juggler
Thanks. The more I learn about Python, the more I want to automate some of the tedious tasks in IClone.
I always welcome ideas If anyone has any needs for useful Python scripts.
PixelDatabase.Net
