Posted 16 Years Ago
Posts: 23.1K,
Visits: 36.6K
Queezi (4/17/2010) Good to know, regarding the install limit. I'm always connected, so I'm assuming that's not an issue. Memo to RL: It would be nice if there were a notice during the install procedure that keep track of the number of installs available!When you install iClone4 a window will come up at the end to tell you the installation is successful. It is on this screen that you will see the number of fresh installs you have used out of your 5 allowed.
Posted 16 Years Ago
Posts: 15.8K,
Visits: 31.4K
I think under Help there is option called One-time Activation, or something, which is supposed to take care of that for all your content. It's discussed on the forum somewhere but I can't find it. :ermm:
Queezi
Queezi
Posted 16 Years Ago
Last Active: 11 Years Ago
Visits: 79
Z, Good to know, regarding the install limit. I'm always connected, so I'm assuming that's not an issue. Memo to RL: It would be nice if there were a notice during the install procedure that keep track of the number of installs available! I'll have to dig deeper to understand the DRM issues, but in a quick test, I've already experienced the logo-screen-of-pain (LSOP) when trying to load a project from one machine to another... Thanks for your input, Queezi
Posted 16 Years Ago
Posts: 15.8K,
Visits: 31.4K
As to the DRM of content, there should be no problem installing it on multiple systems. The simplest is just to copy it from one machine to the other. There are posts on the forum discussing this issue and I wouldn't want you to rant unnecessarily! ;) I hope you were connected to the internet when you uninstalled your iClone. You have five allowed installs, but get "credited" when you uninstall while connected, so you can have five actual installs.
Queezi
Queezi
Posted 16 Years Ago
Visits: 79
Z, I searched the nVidia site at length and could find no more recent notebook version than the one I have -- I even used a couple of third-party utilities that go out and look for new drivers on the web. In frustration, I uninstalled iC4 Pro from my laptop and installed it on a desktop with 3MB of ram and a robust video card. No problems what so ever! The poor HP laptop just wasn't up to the task which is a shame, cause in all other respects it's a fine machine. The best scenario would be to create scenes and animation on the laptop and generate the animation on the more powerful desktop, but that creates a whole other can of DRM worms that will have to wait for another rant. In the meantime, I certainly don't miss funky... Or weirdness, Queezi
Posted 16 Years Ago
Posts: 15.8K,
Visits: 31.4K
I noticed that the version of your driver is lower than the current one for desktops but that seems to be the case for this graphics device. I googled a bit and it seems more people have problems, but no clear solution. As for codecs, there is something called the Vista Codec Package, which installs a bunch of them. For iClone I mostly use image sequences but for test I use the DivX codec that comes with the Vista Codec Package. I'm on a desktop so it's easy to swap out components: I've replaced all kinds of parts of my Pavillion desktop. With a laptop that's not an option. I don't really know what to suggest, but it seems there is something wrong with the graphics driver.
Queezi
Queezi
Posted 16 Years Ago
Visits: 79
Okay, ugh. Just ugh... I ran an uncompressed export and the file was created without incident -- except the video driver bombed AFTER the export was complete! Crossed fingers, held nose (must have been a pretty sight) and went through the un/re-install boogie. No problems, but on the next test export, the video driver bombed AGAIN, but the export completed successfully... Dazed, confused and still plagued by funky weirdness, Queezi PS -- If it matters, I'm running iC4 on an HP Pavillion 9000 with a Nvidia GeForce 7150M nForce 630M graphics card. The driver version is 179.91.
Queezi
Queezi
Posted 16 Years Ago
Visits: 79
Zuijlen, I was just about to take the plunge on re-installing, but now you've given me something else to consider! I have, in fact, been playing around with compression after having a near-fatal infarction looking at the file size of uncompressed HD animation... I'll run another uncompressed test to see if that solves the problem. In the meantime, are some compression applications more stable than others? Is there one you would recommend over another? Thanks, Queezi
Posted 16 Years Ago
Posts: 15.8K,
Visits: 31.4K
If it's during export it might have to do with the codec you are using. Does this only happen with certain codecs? To exclude any codecs, does it happen when you export uncompressed or as image sequence? Codecs are worse than video drivers as there are many of them and conflicts are possible. I have read that some video edting programs install codecs of their own that may conflict with what you already have. So before you install and reinstall iClone I would look into the codecs on your system. There are tools (I don't have their name ready) that can actually discover any conflicts there might be on your system.
Queezi
Queezi
Posted 16 Years Ago
Visits: 79
Gizmo, The funky weirdness manifests itself when I attempt to export animation. It appears as a black screen followed by a warning message from Vista that: "The device driver shut down but was able to recover." After that, iC4 locks up. I checked for a newer device driver, but hadn't considered rolling back to a previous version. Thanks for the back-up advice, it makes me feel better about taking that last step... Which I'm hoping to avoid, Queezi
