Watermark on purchased items
Posted By mauricio444 4 Years Ago
mauricio444
mauricio444
Veteran Member (561 reputation)Veteran Member (561 reputation)Veteran Member (561 reputation)Veteran Member (561 reputation)Veteran Member (561 reputation)Veteran Member (561 reputation)Veteran Member (561 reputation)Veteran Member (561 reputation)Veteran Member (561 reputation)
Posts: 8, Visits: 244
I made SEVEN different dance animations usingIclone 7.83. The motion templates I used for this purpose are"Catwalk", "Change pose", "Twirl hair", etc. Allthe animations for all the dances I made, were combined with items that I purchased from ACTORCORE (“Macarena” and “TheYMCA”) and with the trial version of “Poker Face” (Studio Mocap-Girl Dance /Seductive Dance / PokerFace Dance). After doing a hard work of several days forthe synchronization with the music in each of my animations, such speedmodifications in each Motion, creation of loops, Clip breaking, alignment ofclips, merging of clips, etc., I got the results that I was looking for.
Obviously, an Iclone watermark was always addedfrom the beginning to the end of each animation, since I was using the Trialversion of “Poker Face”.
This watermark was present not only where itshould be, that is: in the place where the Trial version clip was located, butthroughout ALL the animations that contain PURCHASED clips. This situation isvery uncomfortable and harmful at work. The watermark should only be present inthe area where the trial version of a clip is located and not in the entireanimation. I hope you solve this issue in future Iclone versions.
THE MAIN PROBLEM NOW IS: Once I was satisfiedwith the work, I purchased the “Poker Face” animation and downloaded it, butthe watermark is still present in ALL the animations that I did, from the beginningto the end!
What should I do to solve this problem? Is therea way to replace the trial version of the clip in the timeline with the purchasedversion, without destroying the animations created earlier by me, or withouthaving to do all the previous work again? Is there an information panel inIclone that stores the detailed information of the trial clip that has beenaltered (modified duration, warp, etc.), in order to copy that data to the paidclip?
https://forum.reallusion.com/uploads/images/b1d6ff71-c61a-43a8-a5b7-dc22.jpg
https://forum.reallusion.com/uploads/images/3a3d8a63-f956-4d67-afb7-3f26.jpg
https://forum.reallusion.com/uploads/images/13f734ac-feb2-4afd-9751-c8d1.jpg
