Looked high and low and couldn't find an answer, usually means there isn't but thought I'd ask here just in case. Is there a way to disable iClone7 from automatically generating lip sync
keys? I know you can delete them, but if you select a lot of auto-generated
keys after audio import and then cut/delete, it takes a long time to remove them. I'd rather just prevent the lip sync
keys from being generated at import and start with a clean slate. Any insight would be appreciated, thanks!
UPDATE: Sounds like a no. If anyone comes across this and is having the same problem, auto-generate
keys will delete much faster if you don't apply smoothing to the viseme track first. Still a slow process, but seems to work better.
