Visits: 22.1K
Before you try anything else, make sure it's not a case of your equipment not working correctly. IOW, first try doing facial mocap WITHOUT the body mocap to see if it's any better (you don't say how you are doing it, whether you are using Live Face or Faceware, but I do know that RL has done work with using Faceware and the PN suit and the capture is fine. I also know some folks who have improved their Live Face capture with various means). Assuming for a moment it is NOT your facial capture setup, you can always smooth any motion out by sampling the clip, squashing it (to like half the length) flattening the clip and then stretching it back out again. This is a very standard process but you need to be careful you don't lose some quick movements you otherwise want (so you might not want to do the entire clip). Usually it's the body mocap that has issues (which is why I am suspect about your setup).
new-own
new-own
Visits: 353
Bumpikakboo
new-own
new-own
Visits: 353
Hello, I have Motion Live plugin to record my facial + body animation. I use ethernet connection to record the face mocap since it's the fastest and more accurate way. The body's animation is smooth however the recorded face animation is skipping so many frames. It looks quite odd with the body's animation being smooth. Is there any technique to correct this issue? like analyzing missing frames and automatically fills in the frames in between to make it smooth?
