Ascensi
Ascensi
Visits: 1.9K
Hi Eric, could you please talk it over with the team and reenable physics for characters? and have it so that if physics is enabled on a character that the full beard/cloth tracking is enabled by default on the character cloth? I understand it probably wouldn't get the update before iClone 8 but I'm hoping as a CCD member and Elite customer that I can work with Reallusion and have beta access to iClone 8 to help get character physics established as well as helping out with enabling displacement maps in SkinGen (I've produced characters without seam tear issues) This is my work within iClone
Up until a couple days ago since 2019 I only had 14 votes on the feedback tracker, as of today shy of 1 vote it has doubled. I'd like to get it setup ready with particle physics in iClone 8 and function with interaction closer to this: I've done detailed analysis and research to get this happening at my own expense and I probably shouldn't because I don't have a strong income at the moment and wish I was getting paid for R & D.
This should really be setup in iClone not 3DXChange. https://www.reallusion.com/FeedBackTracker/Issue/Request-to-allow-Softbody-Physics-on-character-s-skin-influenced-areas-are-to-determined-by-weight-map-painting
Store Page Link
       AMD 4.5 GHz 16 Cores | 128 GB | RTX 4090 | Window11 | Houdini FX 18.5 | Zbrush 2023 | Maya 2014 | Adobe CS6 | Sonar Producer X3 | iC8, CC4 | DTS Master Audio Suite | Perception Neuron 32 Alum Edition | Akeytsu
davidmaximo
davidmaximo
Visits: 605
Epic update! It's always the little improvements like the realtime color picker, nesting the face expression sliders vertically, allowing the user to punch in their own values on face key, and rotate align tool that I appreciate most.
Eric C (RL)
Eric C (RL)
Last Active: 3 days ago
Visits: 6.0K
Others
- More natural hair for Lewis:
Meet Lewis, our new black male character for the 7.9 update. We reduced the details of Lewis' hair in order to improve system performance. If you feel that your system can handle the extra details, then follow the steps below to bring back Lewis' glorious Afro! - Step 1 - Select the hair and turn on Subdivisions.
- Step 2 -select “Top_Front” “Sides_Back” to the tessellation section and increase Multiplier to 1.
The saw-tooth hair compared to the enhanced Afro (more body and details).
- Embedded Contents Compatibility with Character Creator 3.4
- Shared Templates of FacialHair:
- FacialHair Folder: 8 bear, 4 Hair, 4 Accessory
- Group Folder: 4 beard, 2 Eyebrows, 2 Hair
- Style Folder: 3 Style
- Shared Templates of MaterialPlus:
- Eyebrows Folder: 3 Female_Angled, 4 Male_Bushy
- Hair Folder: 32 Chic bun medium, 9 Short blowback
- Shared Templates of MaterialLib: 4 Beard
Eric C (RL)
Eric C (RL)
Visits: 6.0K
Align Tool with Rotate: Align Tool New Rotate: XYZ available in the Align to menu lets you align rotations for a specific axis.
Eric C (RL)
Eric C (RL)
Visits: 6.0K
Scroll Timeline when Playing New Preference > Control > Scroll Timeline when Playing option lets you decide whether or not the timeline scrolls to follow the position of the play-head.
Eric C (RL)
Eric C (RL)
Visits: 6.0K
Set Default Project
iClone 7.9 now has a Default Project setting to reset the start-up project to factory settings. You can view the current default project under Preference > Project > Default Project, and change the file path with Content Manager > Set Default Project or Preference > Project > Choose Default Project. It is possible to reset the default project to factory settings by clicking the Reset to Default Project button.
Setting default project in the Content Manager and Reset to Default Project:
Eric C (RL)
Eric C (RL)
Visits: 6.0K
Realtime Color Picker
All color pickers in iC7.9 will affect the view-port in real-time, letting one preview the results quickly.
Adjusting the color will only effect the real-time view-port and are not reflective the final settings. It is always possible to revert to the original color by pressing the Cancel button.
Eric C (RL)
Eric C (RL)
Visits: 6.0K
Where to store and remove Vertex Animation
Eric C (RL)
Eric C (RL)
Visits: 6.0K
Face Key UI Layout / Search
iClone 7.9's Face Key > Modify menu will no longer have a side-by-side slider layout, and now comes with a handy search bar.
Face Key - slider column layout Column layout provides a longer adjustable range for detailed adjustments with morph sliders.
Face Key - Search bar The search bar provides instantaneous search functionality for morph sliders containing specific key words.
Eric C (RL)
Eric C (RL)
Visits: 6.0K
Set Clip Speed
Clip Speed for iC7.9 is now shown in percentages (100.00%) rather than magnitude (x1.00). This makes it easier to distinguish and adjust the clip speed. emphasize the precision, and how easy to resume to the original speed.
Right-click on track and select Set Clip Speed to open a dialog window. You can input either the speed in percentages or duration in the desired number of frames (the two inputs will effect each-other).
Changing the Clip Speed will also adjust the number of frames for the said clip.
