Eric C (RL)
Eric C (RL)
Visits: 6.0K
Dear iCloners,
The iClone 7.83 update has now been released! In this patch, we've fixed several bugs to make iClone more usable. You can find the Update tab in Reallusion Hub to download the patch, or visit the update page here. See the full release note below:
Patch 7.83 info
Enhanced: Fps can now be adjusted for exported MP4 videos. (Fps 24/30/60) Fixed: iClone Hair can not be applied to non-standard characters. Fixed: Replacing a character with camera attached causes iClone to crash. (#FT7244) Fixed: Crash as a result of closing iClone after having opened a Python plugin window. (#FT7294) Fixed: Random program crashes as a result of copy and pasting keys. (#FT7239, #FT7252, #FT7354) Fixed: Certain characters will fail to export in FBX. Fixed: iClone tends to crash by enabling GI for projects with Displacement maps.
Visit the link to check what we have updated in IC 7.81 and IC 7.82. Thank you!
Reallusion Team
Posts: 5.7K,
Thank you for the fixes. :):cool:
Amper Sand
Amper Sand
Visits: 5.2K
Eric C (RL) (12/2/2020)Fixed: Random program crashes as a result of copy and pasting keys. (#FT7239) Tried this (my ticket) and the issue is fixed - thanks!
______________________________________________________________________________ Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend In progress: Black Mamba AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Nice, though 25/50 would be helpfull too...
Hard to test as those crashes appeared randomly, but good to know it probably won't happen anymore ;)
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Hm, I have a strange issue since 7.83... Planes seem to have a big impact on fps. All of a sudden I get a huge drop of fps after adding a plane when I make plane invisible and visible again, fps goes back to normal again. Though after a while, it drops again. invisible/visible helps, ... In 7.82 I had a project with many, many planes, had about 17 fps. Adding a plane in 7.83 makes fps drop to 2 fps :pinch: Someone else encountered problems with planes in 7.83??
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Hm, I conceive suspicion that Smart Gallery caused trouble... I closed Smart Gallery window and problem is gone. Damn, I simply have to close that window as soon I start working. I normally have it closed as I already noticed lag with Smart Gallery, but had it open cause I installed new stuff... Though strangely fps drop went away when making plane invisible/visible. Anyway, I hope it was Smart Gallery and I have to keep it closed...
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Nope, even when Smart Gallery closed I have issues. I have only two planes and an animated object (drone with subprops). Project total 58000 poly. After fiddling drone a bit fps drop from 60 to 2. Clicking plane invisible/visible back to 60... Either Plane or Drone causes trouble. Drone never caused trouble before...
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Feedback Tracker: https://www.reallusion.com/FeedBackTracker/Issue/FPS-drop
Amper Sand
Amper Sand
Visits: 5.2K
I just tried your project, but no matter I've done it stayed steady at 60 fps. P.S Because you mentioned the Smart Gallery: instead of closing it, you could try to set it temporarily to "offline" to see if there's some improvement - me I had once a problem with my ISP and the Smart Gallery made the work impossible, but not only affecting the fps, but the whole environment, and @animagic later pointed me to this offline-mode solution.
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Thanx for checking... Don't know why this happens. Will try your Smart Gallery "offline" suggestion. Thanx 😉
