brothertcoleman
brothertcoleman
Last Active: 49 minutes ago
Visits: 6.1K
Is it possible to capture multiple changing positions within one animation using the Import 3D Motions tab or save different animation directions using the projection camera?
It would probably be helpful to have an Affected by 3D Motion option like with G2 characters to help with the strength of the motions.
4 Years Ago by
brothertcoleman
Minnie (RL)
Minnie (RL)
Group: Moderators
Visits: 913
@ brothertcolemanThank you for your advice. Currently, you can manually select the motion range and adjust the projection angle in one 3D motion clip. (see 01:11 at https://forum.reallusion.com/FindPost464019.aspx)
kylelee
kylelee
Visits: 4.2K
Hi brothercoleman,
If you have iClone and Motion Link, you can record the different projection angles at the same clips. Because the import 3D motion just apply motion, but the Motion Link will record motion via Motion LIVE 2D.
