Cartoon Animator Motion Link Plug-in for iClone
With the new updates of Cartoon Animator 4.4, CTA opens the door for tons of 3D motion resources applicable to 2D animation. Yet, there is more! Reallusion takes a huge leap by introducing Motion Link, a plugin installed under iClone. It links between iClone and Cartoon Animator for real-time 3D motion creation and editing that directly projects to the 2D character. iClone as a powerful 3D animation tool allows users to create high-quality and life-like motions, and with a motion link, the motion data can be sent to Cartoon Animator in just a second. Users can real-time preview 2D animation with 3D motions editing in iClone (at the same time), fine-tune the animation with customizable projection angles, and record the editing process to ensure the best animation quality. Y Motion link not only offers a revolutionary solution to expedite motion editing workflow for 2D animation but also unlock endless potential for motion creation.
**Important: The motion link plugin for iClone is installed under iClone. To run this Motion Link Plugin, you will need to install/update your iClone 7 software to version 7.8; To activate Motion Link, the linked software Cartoon Animator is also required to be v.4.4 or above.
Requirement
To successfully activate Motion link, on top of iClone Motion Link, you will need to possess :
** For the Early Access Program, we pre-installed Motion Live 2D plugin into CTA
4. Motion Link Profile for Motion LIVE 2D Plugin (You need to install motion link profile.reg)
>> Check the below posts for tutorials:
