thank you.. i believe i have it.
I bought £1000 worth of software and i believe that came with it.
I will check now
############# update ##########
Yes i have that.. the issue is narrowed down to my model. i tried another model which exported and it worked.
Something is stopping it, i will try and reduce the poly count (286,000) and merge some parts together to see if thats the issue.
Its so frustrating.. im so close lol
######## update#############
After many hours testing different settings and styles the file still wont export to fbx from iclone7.
After i have added my animations in iclone 7 and everything is set.. im then unable to export without getting an export error.
In all my years of using so many software tools ive never encountered something like this and this is the one ive actually paid for out of my own pocket.
is there something i should be aware of to not do when exporting to fbx?
There is zero facial animation because its a robot so i only make sure the body moves perfect.... could this be a factor? do i need to some how switch off facial features in 3dxchange or something similar.
4 Years Ago by
damian_869187
