Rendering in Quick Mode
Posted By shadybearbklyn 5 Years Ago
mikahawkins
mikahawkins
New Member (27 reputation)New Member (27 reputation)New Member (27 reputation)New Member (27 reputation)New Member (27 reputation)New Member (27 reputation)New Member (27 reputation)New Member (27 reputation)New Member (27 reputation)
Posts: 10, Visits: 17
In Quick mode you need high graphics.
Posts: 5.3K, Visits: 16.8K
Do not be confused. It positively makes no difference, but only if you set Render Quality to Final Render at Render tab.
You may then have the viewport set to Medium, Quick or Minimal. The moment you hit Export, the scene viewport is automatically switched to High, scene rendered and then vewport is switched back to the initial mode.
If you however leave export settings at Preview mode within Render tab, the images would be rendered with the current quality for the viewport (High, Medium, Quick, Minimal, or Custom).
shadybearbklyn
shadybearbklyn
Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)
Posts: 337, Visits: 2.8K
Great. That’s what I’ve been doing, but sometimes with a complex scene I’m using quick mode and was wondering if I should continue to switch to high mode before final render. I guess I’ve been doing it correctly;)
charly Rama
charly Rama
Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)
Posts: 1.9K, Visits: 17.3K
Yes, quick mode is done for animate large scene or many avatars with fluidity. When rendering, you have to turn to high for best results
Posts: 23.1K, Visits: 36.6K
You will notice a difference if you render when using Quick Mode. You should use the HIGH graphic setting for best results in your final render.
Amper Sand
Amper Sand
Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)
Posts: 731, Visits: 5.2K
To me, always the "Final Render" was using the "real-time rendering" current settings.
Me too I was was confused at the beginning about this, but then I figured out somehow it makes sense.
______________________________________________________________________________
Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend
In progress: Black Mamba
AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
shadybearbklyn
shadybearbklyn
When you do a final image sequence render, does it matter what the real time setting is set to? I’m assuming that the high, medium, quick, etc. settings only effect what you see when you’re working.
