4413Media
4413Media
Last Active: 8 Months Ago
Visits: 7.4K
Set mesh shader to smooth instead (Using the edge split modifier afterwards will help in certain circumstances.)
Export as fbx instead of a format in obj when working out of blender. Fbx will give you a 1 to 1 scale.
iClone Certified Director and makes miserable Westerns.
Posts: 4.9K,
Visits: 16.7K
Can't you select that flag-texture and change the Opacity to 0?
shadybearbklyn
shadybearbklyn
Visits: 2.8K
I’m using the Oval Office prop from Reallusion and I’m trying to get rid of the flag so that I can use a physics flag prop. Although there are subprops, the entire White House (including the flag) is one subprop. I exported to 3D Xchange and saved it as an FBX. I opened it in Blender and was able to delete the vertices that make up the flag. The problem is when I reimport it into IClone the quality isn’t the same and it’s much smaller. The columns are no longer round, they’re more like octagons. I also need to increase the size by 2000 percent in order for it to match the original. Any suggestions would be greatly appreciated.
