Baffled: getting a black box around what should be masked out
Posted By esemgee 6 Years Ago
esemgee
esemgee
Posts: 168, Visits: 469
I have had no problems doing this in the past, 'this' being adding a label to an object - a beer bottle to be precise. No matter what I do the shaped logo (it is not a square) still has a black surround to it. The bottle shape is from sometime back and was a freebie on the Marketplace, but that should not be the problem - should it?
mark
mark
Posts: 4.9K, Visits: 16.7K
Is the image map you are using a .png?
PROMO-BACK2
Lord Ashes
Lord Ashes
Last Active: 4 days ago
Posts: 1.3K, Visits: 1.6K
You either need to use a PNG file (with the transparent portions being transparent) or you need to set an appropriate opacity.
Using a PNG file will cause the alpha channel (the info about what is transparent) to automatically generate an appropriate Opacity file.
Using other files formats (like JPG or BMP) will require you to create a corresponding Opacity file (pure black where it should be fully transparent and fully white where it should be fully opaque).
Amper Sand
Amper Sand
Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)
Posts: 731, Visits: 5.2K
Me I had the following tricky issue :)
I had a prop and I wanted to edit only the Diffuse image, which was a JPG - so I saved it, I edited it, then I dragged it back into the Diffuse. But something somehow looked different: looking carefully, I observed that when I dropped it, iClone automatically replaced the old Opacity with a new one, auto-generated from the modified Diffuse, which was fully opaque so what should have been transparent become black. So, I redo the whole process, but I also saved the original Opacity image; after dragging the new Diffuse, i also dragged the old Opacity and everything went OK.
______________________________________________________________________________
Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend
In progress: Black Mamba
AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
esemgee
esemgee
@amperfox, @Lord Ashes and @mark. Thanks for your responses. The original image I am using to replace the label is png, and after a slight tweak in Photoshop was saved as png - I have also tried it using jpg with a mask. The png created its own opacity file. Now, everything TELLS me it is png but if I use the opacity the image goes, leaving a black or opaque square. This would appear to be a ghost of the label I am replacing. If I delete the label then the bottle has a totally see-through square, so somehow the bottle was made with this square in it (??Why??), yet I can see no method of how the bottle was made, how to fill this square in etc. So, basically, I am putting on the label correctly, your help confirmed it, but now there is this oddity of a square that should not be there!
Something else that is strange: as far as I can find out this is the ONLY beer bottle in the whole of RL Marketplace. It is free (beer bottle with top) so if you want to have look at it please let me know if there is a way round the problem.
esemgee
esemgee
I have given up, spending too much time trying to solve it - obviously the creators of this (bottle and cap) were learning! There are more bottles after all and what I wanted worked reasonably easily - just some resizing.  Thanks for your help, and, if you ever get bored, there is a little puzzle for you...
Posts: 8.2K, Visits: 26.5K
Reaching way back into the dusty archives of my brain...
Several years ago I struggled with some lettering similar to what the OP described there.  Eventually I found out my "black" background was not pure black.  What should have been 0,0,0 (RGB) was something like 0,2,0.  I had used a color wheel or something like it to pick the black background, and my mouse must have slipped away from the pure-black corner.
Sorry I can't recall more details than that, but it's one more area to investigate.
mark
mark
Might be nice to see a screen shot of the issue as well.;)
PROMO-BACK2
Postfrosch
Postfrosch
Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)
Posts: 6.9K, Visits: 18.4K
Hi Garry,
look this Clip. It works fine with jpg-File
Take no png-File.
Greets Postfrosch
thebiz.movies
thebiz.movies
Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)
Posts: 2.1K, Visits: 42.3K
Hi Garry, just saw this post this morning.  As postfrosch shows the image can be easily changed (at least in my case). The original file was a jpg and had no opacity map.   If you want to remove the label simply use the paint material tool and apply the bottle texture to the label areas.  Please post an image of the black box and perhaps someone can figure this out.
Heres the asset if anyone wants to take a look: https://marketplace.reallusion.com/bottlecap
