G2 Body Composer Kit 3
Posted By ravenzvideo 5 Years Ago
carltond
carltond
New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)
Posts: 2, Visits: 12
Thanks, that did the trick.  That's said I'm not sure why the installer didn't place them there to start? I'm getting some more assets this week. Will let you know what happens after install.
Cheers
Carl
jlittle
jlittle
Posts: 1.9K, Visits: 17.3K
The PartBody and PartHead folders should be under the Cartoon Animator 4 Template directory:
https://forum.reallusion.com/uploads/images/9261c50a-d780-4fa1-b1eb-99c1.png
If you just copied them to the Actor directory then delete them or move them back where they came from.
The PartBody folder should look something like this:
Jeff
jlittle
jlittle
Body parts only show up when you are in COMPOSER Mode, not STAGE Mode. Your Mode is indicated in the lower left hand corner. COMPOSER Mode is where you edit your character.
I'm sure the files are in the correct place and you should put back any folders you moved.
The reason you can't see anything in the folder(s) you moved is that the content manager does not recognize those file types in the body part folders in STAGE Mode. They will only be usable/seen in COMPOSER Mode while editing a character.
The image in my previous post above was taken while in COMPOSER Mode.
Jeff
carltond
carltond
I have a similar problem with G2 Body Composer Kit 3 and 2, also bought symbol Men and nothing seems to work properly. I'm using CTA4 and lots legacy assets seem to be installing in the wrong location or CTA4 doesn't recognize them? where should these files be installed?
If you look at the attachment. I've tried to move a few things and the finally showed up but the folders are empty? Any advicehttps://forum.reallusion.com/uploads/images/2c939013-a113-481f-bd10-a6e2.jpg
jlittle
jlittle
You are probably not looking in the right place.
You have to take a G2 character into Composer Mode and then the body parts will be available there in the Content Manager tab
https://forum.reallusion.com/uploads/images/ea91bb3e-4cea-469c-9c3e-df5e.png
Jeff
ravenzvideo
ravenzvideo
Posts: 22, Visits: 64
Hi, I just bought  G2 Body Composer Kit 3 and I don't see how to use it all.  Did I just get ripped off?
